Is it posible to put a carb on 2.8L
Old Apr 24, 2001 | 10:15 PM
thomas_quinn's Avatar
I already have all the eletronics out and was going to put a 350. But i have 2 friends with 6cyl stangs that think thier cars are fast. So what would i need to switch it from mpfi to carb its a 85.
Old Apr 24, 2001 | 10:34 PM
mulot30th's Avatar
why?
1999 30th anniv. TransAm #877
** BESTS:60ft=1.935 1/4 ET=13.08 MPH=111.8 **
(Only 3.5K miles)
T-TOP,6M-Hurst,12cd, TCS
!EGR * !MAF Screen * ported and polished MAF * !silencer baffles * ! lid baffles * ported and polished TB * removed primary and secundary baffles * sealed ram-air * 9.4k timing-tricker * !CAGS * Mobil 1 * Lou's short stick * BMR panhard rod * BMR poly/poly LCAs * !DRL * Polished SLP resonator catback * 2 Ractive mufflers * 3x3 'fernco' mod * K&N * TB stop grind * Grotyohann headers * offroad Y-pipe* Power pedals * 19+ coats Zaino * WHITE gauges cluster * blue door TA badges * pontiac windshield decal * Polished momo shift **** * 4.5" brosal exhaust tips
Ordered:
Kenny Brown DD SFC
Polished:
Calipers * Hood struts * Air tubes * Valve covers,Heat shields , etc.
Later:Cam + spring + pushrods swap + stage II heads
2000 Black Z-71 K1500 5.3l
ext.cab * !intake baffle * !MAF screen * !EGR mod
Old Apr 24, 2001 | 10:36 PM
Camaro_hunter_d's Avatar
yes you can convert to carb as long as the big mean emissions man does not come calling. If you have a high pressure fuel system the buy a log type fuel pressure regulator and you already have the fuel return line to splice into. Otrher than that you have to buy the intake and carb...If you do convert to carb you may as well take out the electronics and computer. You do have the HEI distrib right?...
Old Apr 24, 2001 | 10:45 PM
Thats the reason i want to switch it to carb had already gutted it for a carbed V8. Dont know about the HEI.
Old Apr 24, 2001 | 10:53 PM
KED85's Avatar
IF YOU REALLY MUST,
go get one from an S-10 Blazer or another F-Body.
OR pay Edelbrock for his 2 piece intake, but, you'll need a carb.
With this intake you can get a 4 bbl.
It would be MORE cost effective to contiue with the V-8 Swap.
Where is all the MPFI stuff?
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Apr 24, 2001 | 11:04 PM
Well i already pulled the computer and wiring harness off of it. I am supposed to be getting a 350 eventually and already have a th400 tranny in the basement waiting. Just dont know if that stuff will go in the 85 or a 1st or 2nd gen.
Old Apr 25, 2001 | 06:41 AM
cbpldc's Avatar
What year 6cyl stangs are they? I guarantee that they will spank you if they are 93-up 6cyl's, especially if you have no other mods to your engine. And that means double if you go with a stock carberator setup.
I had a computer controlled Carb on my 6cyl bird and I went to non-cc because my carb went bad and was too expensive to replace. So I bought an '82 carb off of an S-10 and replaced the distributor with one from another 82 S-10 and it runs good, other than that annoying check engine light all the time.
Chris
Old Apr 25, 2001 | 02:55 PM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
This is from the 1999 Edelbrock catalog:
For a 4 barrel set up you will need the base (manifold) part number 3785 the top (non EGR) part number 3789. They recommend Holley Carburetor #0-8007 (390 CFM)
The price back in '99 was $213.95 for the base and $111.95 for the top.
Dale Earnhardt was a scholar of the race track that drove with the spirit of a warrior.
My Camaro: http://home.earthlink.net/~singleton052095
Old Apr 25, 2001 | 09:45 PM
ones a 86 or 87 the kid wouldnt know how to change his oil he didnt even know the engine size until i checked it. The other is a 68 with a 200.
Old Apr 25, 2001 | 10:59 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
i don't know how the carb will hold up against em, my 85 2.8L H/O with MPFI would run with the new stangs,93- till they changed the body style, and upped it to 190hp, but at that time, i was running on 4 cylinders too. My new motor, will run with the older 3.8L's 93-97 or so, all day, and i beat my buddy's 96 stang with a stick against my auto. the 200 shouldn't be to big of a problem, being that it's an older inline six, and might not have been upkept, but just give it a try, don't do anything to boost their ego's thouh.
the 85 firebird, the first firebird that doesn't burn out....
It eats the pavement!!!
KILL LIST: (SHORT BUT GROWING)
Dodge Daytona (think a 2.2),Honda Acorda (2.0L),2000 Camaro (3.8L),1992 Mustang (V6),1987 Firebird (2.8L),80's probe (4 banin'),90's malibu,90's 4 door Saturn, (wow, that was a slow ride, even slower than me.),91 Celica GT conv.,Acura Integra, 5speed DOHC 4 cylinder. * 86-90 Pontiac T/A, 305ci. (might not have been running well, but i'll count it anyway.), mid 90's Ford Mustang GT 4.6L tags. (beat him in a turning contest), 3rd gen RS camaro( beat him by more than 2 cars), Celica GT (this guy was a crazy racer)
---came close----
1979 camaro (5.7),1981 camaro (5.7),1982 firebird (5.0) my tires spun, I coulda beat em!!! ,79 El Camino (350, lost by a door),96' Mustang, 3.8L stickshift. (caught him after my car downshifted.)
Old Apr 25, 2001 | 11:27 PM
KED85's Avatar
Where do you find rust free cars of the first and second generations in MA?
Sell this car and buy the right car for the mission.
Out in CA, they sell for as little at $1,000 or so.
I'm NOT syaing what condition. In fact, someone once gave me a 1969 Camaro, shell.
I could made it into a Trans Am racer. Came with roof, front inner fenders, shell of body (no quarter panels or doors), no glass, no front end or subframe.
BUT it was a console car with a 12 bolt! My future father in law, saw it in his garage and flipped, so I parted it out. Yea, you know I kept the 12 bolt and sold the front inner fenders.
It happens. The car was rust free and straight.
Gotta visit out here.
Buy plane ticket with funds from car sale!
Chat Soon,
KED85
Karl
Old Apr 25, 2001 | 11:57 PM
I like this car to much to sell it. I have a 95 escort i am going to sell to get a first or second gen. Atcually my mom was talking about a vacation to CA.
Old Apr 26, 2001 | 04:15 PM
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
there is no such thing as a rust free car in MA. I HATE THIS STATE!!!
Infested
May 22, 2018 11:56 PM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
GVMV
Aug 16, 2015 08:01 PM
cstrobel65
Aug 15, 2015 10:19 AM
