How to make A.C Delete???
Old May 17, 2011 | 09:29 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
I recently removed my A.C because it was in bad shape....I wanted to know if anyone has made their own Delete because the ones for sale are way to much. There has to be a easy way to make them....I hope!!
Old May 17, 2011 | 10:51 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: How to make A.C Delete???
Do a search on the Cooling (or V6?) board. Someone did out of sheet aluminum. It has pics and some instructions. You may need to read through several threads. I don't remember the exact one.
Old May 17, 2011 | 10:57 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
All I did on mine was buy a shorter belt. No delete pulley needed was needed for my 3.1. That was before I swapped the V8 in of course.
Quick search on Autozone's site shows part numbers 5060905 or 905K6 should work
Old May 17, 2011 | 12:51 PM
fasteddi's Avatar
Car: 1991 Camaro RS
I Already have the smaller belt and i took all the a.c stuff off except i didnt delete the fan spot on the firewall... ill look at some threads on the ac and see if i can find more... sheet metal does sound like a good idea.
Old May 17, 2011 | 01:47 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
All you need to do is setup the belt/s differently, quite easy, I honestly don't know why people spend money to add weight and drag back in with delete pulleys....kinda defeats the point imo.
Old May 17, 2011 | 02:27 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
So you are asking about A/C Delete Blower box? I thought you were asking about the A/C Delete Pulley for the serpentine belt. If you don't mind not having heat you can just remove the blower motor and box and block it off with a piece of sheet metal.
If you want to keep the heater and/or blower motor, you can use the blower motor and box from an 82-97 S10/S15/Jimmy/Blazer without A/C. It isn't a 100% perfect fit and requires some minor modifications to work, but its very easy to do. Best of all, the box and motor can be had from a JY for much less than a Thirdgen A/C Delete box.
Old May 17, 2011 | 02:32 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
I'm in the same boat. Just removed the compressor etc and used a shorter belt. I haven't got the whole box thing straight yet. But I did see a thread where someone just made a housing that added to the right of the existing blower motor. I'm not sure what's required on the inside of the firewall. If anything.
Old May 17, 2011 | 02:47 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Originally Posted by Base91
....I'm not sure what's required on the inside of the firewall. If anything.
Nothing. All changes are in the engine bay.
Old May 17, 2011 | 03:10 PM
fasteddi's Avatar
Car: 1991 Camaro RS
yea i want to keep the heater going....Right now i just kept the filter in the old box and it works fine but looks ugly. Im going to try and bent some sheet metal and see if i can get that to block everything off and look nice too... Ill put up pics when i do it...
Old May 17, 2011 | 04:51 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Do some searching. A guy posted pics and tips and his looked really neat. I want to find it again to do the same.
Frozer!!!
Jan 19, 2024 04:55 PM
Out-Cast
Aug 22, 2015 07:49 PM
BlackphantomZ28
Aug 21, 2015 07:12 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
drathaar907
Aug 6, 2015 04:20 PM
