v6 multiport fuel pump pressure???
Old May 22, 2011 | 10:41 AM
fitojdj's Avatar
Car: Camaro RS 1992 25th
Engine: 3.1 L 191 cid LH0 60° Gen II V6
Transmission: Automatic
Axle/Gears: Heritage Package (RPO Z03)
Hi everyone my a got a camaro 92 v6 multiport... and it was parked by 6 years... i changed the fuel pump and the inyectors (cause the went off)..
and it works.... but just 2 days.. and it was working kind of lazy...
and sometimes work well..!.. a mecanic says we need to check the fuel pressure on the fuel lines...
but he dont know wich is the pressure of this kind of cars...
anyone knows???
have to be high because of the multiport.. thanks..!
i recorded some audio for the last time i tried to cranck..
Camaro Fail Mp3
Old May 22, 2011 | 10:50 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: v6 multiport fuel pump pressure???
Nominal pressure is 43.5 psi. Service pressure is between 42 & 47 psi. The test port is behind the plenum in front of the distributor.
Don't forget the fuel filter. Located on left side right in front of rear tire.
RBob.
92camaroJoe
Jul 29, 2023 07:57 PM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
