Rattling sound
Old May 7, 2001 | 08:27 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Rattling sound
A few weeks ago i started hearing a rattling sound like something in a tin can bounceing around lightly. I thought it was bad gas but 6 fill ups late all different stations its still there. I changed my oil lastnight hopeing that my help of couse it didnt. It only does it at WOT and occaionaly at moderate throtle. Any ideas what it is. Its comming fromm the drivers side.
Old May 7, 2001 | 10:24 PM
MikeysLil86camaro's Avatar
Wow, i haven't been here in a while! how the hell are all of ya? My guess is that it would either be your flywheel, or, more convienient, your heat shield above your exhaust. When your flywheel cracks, (which happened to mine, twice!) It makes a rattling sound, which goes away after a certain amount of RPM's. The rattle gets louder and faster until a certain point, then stops after RPM's are high enough. A pain in the @$$, because u have to pull your tranny to replace a 35 dollar part.
What would be a lot more convienient is if your heat shield had become a bit loose, and was rattling against your exhaust. The lower the RPM's, the lower the friction, therefore the noise will be more audible. More RPM's, more friction, the noise becomes too high pitched for a person to hear. All I did was take a few screws and drill the shield up with some heat-proof rubber inbetween, and the noise is gone. Your problem might be neither of these, this is just the experiance i have had with rattles in my car.
Old May 12, 2001 | 02:40 PM
FAST RS's Avatar
I coudlnt find any heat shields on the driver side. It almsot sounds like its comming from the engine
Old May 12, 2001 | 08:19 PM
FORD Rustangs -R- Us's Avatar
i got that same thing on my new bird, back right side of car. i thought it was the jack coming loose and was gonna check it tommorrow! god i hope its nothing big like that
1992 Firebird automatic, brand new engine/tranny/brakes/tires..paint is getting touched up- Medium blue
Mods that came w/car - New dual exhaust, maybe lowered cause the tailpipes (angled down 1 inch) scrape on driveway and so does front end..the accual fascia gets stuck if u go less than 2 mph! maybe new wires/plugs, and deff. a POSI unless the car came with the 2 wheel tire spin rear
"The 92 firebird..not the first to burn out..OR eat pavement, but does a D@MN good job at it! I got pics to prove it!"
"Never let a girl drive your car, unless ur looking to part it out"
Old May 12, 2001 | 08:45 PM
FAST RS's Avatar
No mine is comming from the Engine when im at WOT or half throtle it will make this griding sound for a second then go awy its not a constant sound.
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
