nasty smell/smoke/fluid coming from exhaust
Old May 13, 2001 | 10:53 AM
FORD Rustangs -R- Us's Avatar
when i first got it i noticed it smells kinda odd..then it gets worse and worse and one nite i saw it puke white smoke when idleing, and i figured it was normal, but now it smells soooo bad, and white smoke always comes out not alot but noticeable if u look, and when i start my car and rev it up and turn it off and get out there is 2 piles of fluid under the exhaust pipes..whats wrong?
1992 Firebird automatic, brand new engine/tranny/brakes/tires..paint is getting touched up- Medium blue
all stock
"Never let a girl drive your car, unless ur looking to part it out"
Old May 13, 2001 | 11:18 AM
KED85's Avatar
Is this AM or PM when the white smoke happens?
Morning is condensation. Normal.
PM is possible signs of a worn head gasket, and loosing fluid in the combustion chamber.
Have one of the mechaincs at you Dad's place do a couple of simple tests, that they know of.
Keep an eye on the radiator fluid level!
Nasty smell could be just living in Maryland! J/K!
It could be the water hitting the CC and the reaction to it, especially in the hot humid days. I had a 1975 Vega do that, it smelled of rotten eggs. It was the Convertor & the humid days.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old May 13, 2001 | 01:16 PM
aight thx, ill have em look at it when they fix the door and such. its just one of those little things that are embaressing could a head gasket problem cause a decrease in performance? my friends 93 BMW 318 is 5 spd with just an intake and exhaust beat me by a car length last nite and that is just a little inline 4!
all stock
Old May 13, 2001 | 01:46 PM
Mike Harvey's Avatar
That is regardless. That BMW w/ the inline four would of beat you even if you didn't have a blown head gasket. The BMW's have a blue printed & balanced inline engine, of course it would beat a 60 degree V6, that's straight up common knowledge.
Also of course you are going to loose power by having a blown head gasket.
Also why the hell would you race your car when you have a blown head gasket. While that gasket is blown are you not supposed to drive it cause water is now in your oil.
- Mike Harvey -
1986 Firebird S/E
Old May 13, 2001 | 07:21 PM
KED85's Avatar
I have driven cars with bad head gaskets.
My S-10 Blazer is that car.
It finally gushed chocolate milk all over the engine compartment.
I'm fixing it now, but, I did drive it for a bit.
Chat Soon,
KED85
Karl
Old May 14, 2001 | 01:36 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You might not want to start the motor up and then rev it...
Street Lethal
Apr 30, 2019 12:14 PM
TheExaminer
Aug 26, 2015 04:59 PM
db057
Aug 22, 2015 08:17 PM
86White_T/A305
Aug 17, 2015 12:16 AM
