VSS code 24
Old May 13, 2001 | 04:50 PM
matlock's Avatar
Car: 89 GTA
VSS code 24
Once in a while I will get a code 24 when my camaro is in motion. It signifies that my vehicle speed sensor is malfuntioning. I believe it is just a bad wiring connection because sometimes my speedo works, sometimes it will bounce around, and sometimes it will not work at all. Anyone know how I can fix this?
87 Camaro Sport Coupe
MSD Coil, Accel 8.8mm wires, Rapidfires
K&N Filters, No Air Baffles
Z28 Hood and Rims
Old May 14, 2001 | 01:40 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The speedo acts up? Hm. Electronic speedo's weren't around in '87, were they? Check the tailshaft of your tranny on the driver's side. See if you have a speedometer cable or a bunch of wires exiting the back. (Note that you'll have a 3-wire connector on the driver's side above the tranny pan; that's the TCC connector... look further back on the tailshaft, by the driveshaft).
If you have a cable (and I think you do), then maybe the cable is worn out. The VSS on cable-driven speedo's is located on the back of the speedometer itself! It's a yellow box that you can see with the top of the dash off. Anyway if the speedometer bounces, it's not being caused by the VSS, it's caused by the cable; and I guess the computer's sensing the burp in the VSS signal.
Unless of course your '87 has the electronic speedo, meaning the VSS is in the tailshaft of the tranny...
Anyone else?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
