Help on idle problem while driveing?
Old Oct 2, 2000 | 11:08 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
This isn't for my car but my cousins 92 3.1L RS. When he's parked sometimes it'll idle fine and when it doesn't it rev's in 200rpm increments. For example from 1000 to 1200, and sometimes when he lets off the gas and hits the brake, it start idleing radical...
What would cause this and how do i fix it? If its the IAC or TPS whats the specifications on the settings for it? I've never owned nor worked on a v6 so i don't really know much about the settings....
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-Rebuilt 700R4 Tranny
With the goodies to go
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
Old Oct 3, 2000 | 12:23 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I read your post wrong sorry
[This message has been edited by FAST RS (edited May 14, 2001).]
Old Oct 3, 2000 | 01:09 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Well, the TPS/IAC adjustment is the same for the v8 cars. Tom K's car is featured in this month's Hot Rod Magazine, giving the adjustment procedure. I'm not sure if the mag has hit the newstands yet, but in the upper right corner, the cover says "Free TPI Fix", and shows two Camaros on the front.
I believe the car is supposed to idle at 600-800 RPM's, and the TPS should be at 0.45 volts with +/- 0.05 tolerance. (0.40 to 0.50 volts) You might also want to check the TPS voltage at WOT... the books say it should be at 4.5, but my car only goes up to 4.28. I'm not sure if that's standard or not.
You could also try cleaning out his throttle body, and the IAC passageways. Remember when you remove the IAC from the TB to have the IAC unplugged & car off! Don't turn the car on until the IAC's back in and plugged in. Otherwise you'll have to play with the IAC motor- it's a hassle that's easily avoided.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old May 14, 2001 | 06:36 PM
89IROCZ
Guest
Posts: n/a
oops, meant to reply to a different thread.
[This message has been edited by 89IROCZ (edited May 14, 2001).]
Old May 14, 2001 | 07:37 PM
CanadianCamaro's Avatar
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
Transmission: T-5 5-Speed Manual
If you have problems finding the article on cleaning out the IAC passageways (as I did) I found them here:
https://www.thirdgen.org/messgboard/...ML/001246.html
I'm going to try this myself as soon as it STOPS RAINING!
Old May 14, 2001 | 08:10 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
IT"S YOUR IAC, I had the same problem, just replace your IAC and if you have to, your ECM because when my IAC died it poped that part of the ECM, works fine now.
Old May 14, 2001 | 10:04 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Heh, sorry guys. This post was answered a long time ago. Not sure why it was resurrected. heh. Good night all
89 IROC-Z 350 TPI
-Flowmaster Catback
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
-Gutted Air Boxes
Infested
May 22, 2018 11:56 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
