offset
Old May 29, 2001 | 11:41 PM
F-BOY's Avatar
offset
Does anybody know if the offset on a 89 firebird 2.8l is the same on the front and back? Am I able to rotate my back rims to the front so I don't need to dismont the tires?
thnks
Old May 30, 2001 | 06:15 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
If you have stock 15" rims you should be able to rotate the rims and tires front to back. I think only 16" rims are front and back specific. Usually there is a "F" or "R" on the rim if it is front or rear specific.
[This message has been edited by Mikes86SC (edited May 30, 2001).]
Old May 30, 2001 | 10:12 AM
KED85's Avatar
I'll bet, you need not worry.
The "Bigger engine" cars had those type of tires, from the factory.
The 2.8s & such, just had the simple stuff, until we got ahold of them!!
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old May 30, 2001 | 04:55 PM
F-BOY's Avatar
thanks for the help guys, yeah I forgot to mention that yes they are stock rims
Old May 30, 2001 | 05:01 PM
KED85's Avatar
When ya swap the wheels, make sure you put some oil on the wheel studs.
Helps make the lug nuts go on easier and also come off, easier. NOT SPRAY STUFF, motor oil, thick stuff. A film, few drops, etc.
NO, the lug nuts will NOT loosen while driving!
I've been doing this for years. I swap my own wheels and tires, a friend mounts and balances tires for me.
IF ya change/rotate wheels, every 5,000 miles, the wear pattern is great!
Chat Soon,
KED85
Karl
Old May 30, 2001 | 05:49 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
umm..ive been told if u look inside the rim there is something printed on there "front" and "back" because we have diff offesets..was that info wrong?
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil (Fireball in future) Accel 8.8 wires, MSD Ignition Module, Auto Meter Gauges (Water, Clock (needed one) Fuel Pressure, and 5" monster tach) 4th Gen Seats
--For Sale--
(Who says drumsets are cheap? selling my car to get a new one..) EMAIL ME!
" I'd rather run last in a full out race, than to NOT run at all ".
Old May 30, 2001 | 06:02 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Ked85
<font face="Verdana, Arial" size="2">Helps make the lug nuts go on easier and also come off, easier. NOT SPRAY STUFF, motor oil, thick stuff. A film, few drops, etc.</font>
Good sugestion. I use Anti-seize, Never-seize(whatever it is). Its great stuff. If I take anything apart, it goes back together with that. I just thought I'd recommend it. Its about $15-20 a can, but you could take every nut and bolt out of your car an coat it, and the can would still have some in it.
Old May 31, 2001 | 05:28 PM
F-BOY's Avatar
cool Joe_L I've rotated the rims already but I'll be sure to check that stuff out. since its on that side of the country, it should also be over here then
Old May 31, 2001 | 08:56 PM
Camaro_hunter_d's Avatar
Anti seize is good stuff... use on lugs, caliper bolts, exhaust studs and any other high heat/high rust nut-bolt.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
rb85TA
26
Sep 14, 2015 10:29 PM
