Dies unless warmed up...
Old Jun 4, 2001 | 02:43 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Well, my car quites unless I start it, and hold it at 1500-2000, for 1-3 minutes or so. Once I start driving it down the road it is fine, and it won't quite again. I was wondering what would be causing this.
Every now an again (Once every 2-3 days) the engine light comes on (I haven't seen it now in about 4 days)
I was wondering if an O2 sensor could be causing my problems?
1987 Firebird
2.8L Auto
T-Tops
New Paint last Fall
No mods yet...
Old Jun 4, 2001 | 03:33 PM
AlexJH's Avatar
Engine: 5.7L V8
Have you checked the codes? There is a technical article on this site that tells you how to do it.
Old Jun 4, 2001 | 07:14 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
I had a similar problem with a 87 Grand Am. Turned out the MAT (manifold air temp) sensor was bad. If your codes point to it, be careful you don't overtighten the new one. I did and crushed it against the inside of the manifold.
Gunner242
Dec 25, 2015 04:49 PM
Giocio
Oct 1, 2015 12:20 PM
Luigytico09
Oct 1, 2015 08:46 AM
mfp189
Sep 27, 2015 09:25 AM
