Fuel Pump
Old Jun 8, 2001 | 05:48 PM
Kyle F's Avatar
Fuel Pump
How did you guys change your fuel pump. I heard you could lift the carpet and cut a little window out of the floor board and lift the pump out from there. If this is true how do you pull the pump out? Cause I know the lines twist a little in the tank?
Old Jun 8, 2001 | 10:27 PM
Camaro_hunter_d's Avatar
well the best thing for the forst time is to do the time consuming task of dropping the tank. After you get it out pull the carpet back and make a line where you saw the fuel pump lined up under the car. cut it out. but remember to get a rubber or plastic body plug to fill it in when not in use. You can even get a double channel rubber gasket and use the same piece you cut out, just trimming it a little more. Just remember to tack weld a piece of metal to use as a handle so you can pull it out again.
Old Jun 8, 2001 | 11:49 PM
Kyle F's Avatar
Well I have already cut the whole just cant get the pump hanger out far enough to remove the pump! How do you get it out.
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Past Thirdgen:
86 Trans Am w/ built 355TPI with SLP goodies and too much other stuff to List. One sweet *** car, wish I would have had a good enough Job to pay insurance on three cars so I could keep it, but for a 89 Turbo Trans Am w/ Low miles, I think I made the right choice!
Old Jun 11, 2001 | 09:54 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I dropped the exhaust and axle, then the gas tank.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jun 11, 2001 | 12:56 PM
You may have to reach and try to release the brace tretaining bars. Mine had a few of those cheap bendable things. after I streached them out it came out fine...Also when you get it all apart install a longer peice of fuel line so it will be more flexable and be able to move around alot more.
Old Jun 12, 2001 | 10:58 PM
Kyle F's Avatar
Done, cut the lines and patched it back with MPFI high pressure fuel line. Takes 10minutes to get it back out of the car. We did for ****s and giggles.
Past Thirdgen:
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
