HELP?!? new car no idea what im doing
Old Jun 12, 2011 | 07:54 PM
cha_chard's Avatar
Car: 89 Camaro RS
Engine: 2.8L V6 MPFI
Transmission: 5Speed
Hi guys i just bought a 85 firebird with the 2.8 V6 in it and it was overheating
so what i did was i replaced the water pump and thermostat
so a couple hours later i thought i was good it seemed fine until i smelled and saw smoke from my head -_-
and since i have the dummy gauges i can't see the temp on the dash i killed it and thought that it might be the fan. Andy ideas before i invest in a new fan??
thank you all you are the best
FIRST POST yee haawww
Old Jun 13, 2011 | 12:21 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: HELP?!? new car no idea what im doing
check the fluid levels and that you don't have any leaks, but sounds to me like it wasn't overheating, possibly something came in contact with the exhaust manifold(ie. a wire most likely) and started to melt, could also have a crack in the block or something else unpleasant, but the idiot light if working would come on if the temperature reached past nominal levels.
Old Jun 13, 2011 | 09:05 AM
Guest
Guest
Posts: n/a
If the valve cover gasket leaks oil onto the exhaust manifold, that'll make smoke.
RazorN8
Jan 7, 2022 11:44 AM
Wade787b
Sep 29, 2015 01:15 PM
B_Dubya
Aug 26, 2015 05:09 PM
drathaar907
Aug 10, 2015 07:44 AM
