What's wrong now????
Old Jun 18, 2001 | 12:42 AM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
Ok when my V6 3.1L Camaro is cold, it is real doggy and when you push the gas from a dead stop it will jump up in RPM then die/drop off in RPM then if you mash it, it will cough then jump up in RPM and then it shifts into 2nd and is ok. But it will do this until the motor gets warm. If the car is at normal opperating temp. it is smooth as glass. I've done a TV cable adjustment, that helped the tranny but I'm thinking I need to advance or check my timing, am I right??????
Old Jun 18, 2001 | 09:03 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Honestly, sounds like the motor needs to warm up first. A major tuneup would probably cure this... and that includes timing. Click on search at the upper right of this message, and search for "Major Tuneup"- you'll find my message.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jun 18, 2001 | 11:35 AM
Ok I've done plugs, air filter, pick up coil, new MSD coil, new cap and rotor, new ignition module, new after market leads, new oil, coolent, transmission flush, new IAC and TPS, butter fly cleaned up, checked for codes there is none, TV cable adjustment, new altnator, new belt, new battery, new cap, all new heat hoses, topped off the A/C, so I guess the only thing I need to COMPLETE THE TUNE UP is check the timeing and change the fuel filter. CAN ANYBODY THINK OF ANYTHING ELSE??????????
Old Jun 18, 2001 | 12:14 PM
Camaro_hunter_d's Avatar
well would have checked the timing first. Thats probly the prob. If it bogs down weither cold or hot its more then likely the timing. I can rev my motor cold and it spools up fine. Cold or hot should not matter. I have started up in -10 degree weather and drove it just seconds later and it has never given any probs. Well once it did when I had it for 3 months so I reset the timing and it was fine afterwards... Its now been over 18 months and still no probs.
Old Jun 18, 2001 | 02:34 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
How did you adjust the TPS sensor's voltage at idle? Don't forget about the PCV valve, but that wouldn't cause your stumbling problem.
Old Jun 18, 2001 | 11:19 PM
I didn't adjust the voltage, I just replaced the TPS because it was jumpy when I read it with a meter, I did adjust the TV cable
Old Jun 18, 2001 | 11:45 PM
Xenodrgn's Avatar
Correct me if I'm wrong, but if you install it, it doesn't mean it's set right, you still have to move it up and down to get the correct reading, right? Or does that come factory set correctly?
If setting the timing doesn't help, start checking injectors. Get yourself a spare set from the junkyard to use while the ones you send out to cruzinperformance are being worked on.
1985 Camaro SC - 2.8L, auto.
Mods:
Removed air baffles, mandrel bent cat-back pipes (but stock replacment muffler, Dynomax Turbo and Catco converter are on thier way)
Old Jun 18, 2001 | 11:49 PM
TPS is set at the factory no way to change, I'm going to check the timing again, I did when I put the new pick up coil on but maybe I'm off a few degrees.
Old Jun 19, 2001 | 09:10 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Xeno, that reminds me; there was a discussion a while ago about the later model TPS's; they were self-adjusting. On startup & idle, the computer would memorize that voltage as "idle position", and go from there. It's not like our 85-89 computers that need to see 0.55 volts to know they're at idle.
Old Jun 19, 2001 | 10:04 AM
KED85's Avatar
IF your engine is old, put a timing light on it, to see how bad the timing chain is.
IF it's old & stretched, it could be the cause.
To see this, just hook up the light to your engine and have it started. IF the timing mark jumps jumps around, you may have found the problem.
ALSO, look for any vacuum hose leaks. You may have some, too. Watch out the plastic lines break real easy.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Jun 19, 2001 | 11:36 AM
Ha I don't think my timing chain is worn or anything with only 72,000 miles
Old Jun 19, 2001 | 12:52 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I'm sure it is. The recommended replacement interval of a timing chain is 25,000 miles- although they last much longer. I changed my original out at 180,000 miles- what a difference!
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Dyno Don
Jan 24, 2016 08:24 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
