Alternator Question
Old Jun 18, 2001 | 10:00 PM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
Alternator Question
I already posted this on the electronics board but I thought I would post it here also.
I purchased a new alternator awhile back and today I noticed that the 8mm bolts that go through the case have come loose..does anyone know what they are suppose to be torqued too.
Thanks in advance for any information.
Dale Earnhardt was a scholar of the race track that drove with the spirit of a warrior.
My Camaro: http://home.earthlink.net/~singleton052095
Old Jun 19, 2001 | 03:52 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I just put them so i know they are TIGHT use some stuff by permatex i think it comes in a blue bottle its a threadlock so the bolts dont move
Old Jun 19, 2001 | 12:56 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I'll look it up tonight. I'd imagine though that an 8mm bolt gets the same torque any other 8mm would... isn't it like 15 or 20 ft/lbs? Someone might've posted the "fastener thickness / torque" chart on the tech board a while ago...
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jun 19, 2001 | 01:25 PM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
According to the "Chilton Manual" 8mm bolts get torqued to 7ft lbs but I didnt' know if that was the same for the alternator being a thinner bolt...any ideas what 7ft lbs converts to inch lbs.
Old Jun 20, 2001 | 10:35 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I couldn't find a torque spec anywhere for those thru-bolts...
Do you just multiply by 12? 7 foot lbs = 84 inch lbs? Someone went thru this a while ago on the tech board, too...
Old Jun 21, 2001 | 12:39 AM
Camaro_hunter_d's Avatar
me personally would go to hand snug plus 1/2-3/4 turn. that should hold it. Threadlocker may also help. There are torque specs for everything, but rarely are they actually needed in the "real" world. We know how tight it should be most the time. Now engine bolts yes use torque specs but for everything else mostly use common sense.
I mean the torque spec for the GEO wheel nuts are 35-40 LBS...Most think that is way too little so we do it at 70-80 LBS
Cornholio7979
Sep 20, 2018 02:31 AM
dutch930
Sep 11, 2015 06:58 AM
Cleotiz
Aug 23, 2015 12:07 PM
redmaroz
Aug 16, 2015 11:40 PM
