Tearing plug wires
Old Jun 26, 2001 | 05:48 AM
Luke's Avatar
Car: '86 Camaro
Engine: 2.8 MPFI
Tearing plug wires
Anybody have a problem with this when changing spark plugs? Seems like every time I chang the plugs, I rip the little copper cap that conects to the plug out from the wire boot. Only realy happens to about 2 or 3 of the wires. So ive gotten used to buying a set of wires with my plugs. Ive tryed to lube up the conectors with that KY for spark plugs grease one gets from a parts store. But that didnt work either. The next time I would change the plugs, the same thing happenes. Any suggestions?
Old Jun 26, 2001 | 09:12 AM
Brian K's Avatar
Quality wires.... I have had Accel and ow Crane wires and never had one rip. Now I buy a tube of dieletric greese. Fill the wire with it and it oozes out as I put them on. I also use the factory heat sheilds for the wires and not once has one ever ripped.
Old Jun 26, 2001 | 09:21 AM
KED85's Avatar
Yea, it's common. Even on the good ones,if ya not careful.
How is this problem solved?
I'd like to try the spark plug boot puller pliers trick, to see if it works.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Jun 26, 2001 | 04:07 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I always use the dielectric grease on the boots. Once, my MSD 8.5mm wires burnt on the plugs, and the boots ripped- I had used dielectric to install 'em, and yes, I was twisting/turning the boot as I was pulling them off.
MSD replaced them for me for free. It's never happened again; must've been a defect, I guess.
Always pull on the boot, not the wire, and twist the boot as you go. Remember, lube the inside of the boot, not the spark plug terminal, with the dielectric.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
g.l.mos
Aug 22, 2015 12:02 AM
djmarch
Aug 19, 2015 12:07 PM
