OK, whats your 1/4 mile times on Nitrous???
Old Jun 17, 2011 | 08:10 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Ok im am definitly buying a single fogger wet kit for my 3.1L next week...What are anyones times at the 1/4 mile on shots of 75, 100, 125 and so on??? I'm in question if i should buy a kit that supports 75hp or one that supports 125Hp. Im tight on $$ but am doing everything right...blow down tube, blanket, and rpm window. Just curious of times of ppl with the nitrous. Car curently runs 16.8 constantly. Thanks!!!! Also Im not planing on blowing this thing up... It has 104k on it and is daily driver and weekend racer...nitrous for mainly track only.
Attached Thumbnails OK, whats your 1/4 mile times on Nitrous???-cleanblackintakesmall.jpg
Old Jun 17, 2011 | 08:24 PM
project89's Avatar
Re: OK, whats your 1/4 mile times on Nitrous???
by the largest kit u can afford the only thing different in most kits is the amount of hp the soiliniods will flow.so what u do is buy the biggest kit u will ever use and then just jet it down to a lower shot.
btw most kits seems to range like this
35 threw 125 hp then 125 threw 250 then 250 and up
id buy the 125 and up kit and just jet it down to 75hp in reality i would start at 35 then bump it up to 50 then finally to ur end shot of 75 hp
just to be sure that everything is working correctly and u dont screw anything up
this way if somehting is wrong u have a less likley chance of hurting the motor on the small shot
Old Jun 17, 2011 | 11:34 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
125+ wet kit
even Holley wasn't worried, when they sold them, it was a 125HP dry kit.
which had to be in the safe range for stock.
They didn't get a good rep blowing up engines
Old Jun 20, 2011 | 01:31 PM
fasteddi's Avatar
Car: 1991 Camaro RS
ok well i guess no one has any quarter mile times on nitrous??? well ill put mine up here very shortly so that everyone can see...
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
evilstuie
Jan 9, 2020 08:29 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Andrew6.688
Dec 13, 2015 10:59 AM
