fuel filter help
Old Jun 18, 2011 | 12:21 PM
4g63's Avatar
fuel filter help
where is it located and is there any special tools needed to remove or is it just a wrench
i tried looking behind the driver rear tire but couldnt find it
Old Jun 18, 2011 | 12:24 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: fuel filter help
It's under the driver's side just ahead of the rear wheel well... You'll want a drain pan under it to catch the gas that will stream out when the filter comes off.
Old Jun 24, 2011 | 06:22 PM
89Camaro88's Avatar
Car: 1989 Camaro RS
Engine: 2.8l V6
Transmission: Auto 4
What were your issues indicating you needed a new fuel filter?
Old Jun 26, 2011 | 01:55 PM
4g63's Avatar
it might be a new pump but i just wanted to try the filter first the issue im having is the car looses power no matter what gear im in p r n d d 2 1 it wont rev past half throttle hafter that the car just kinda dies out
Old Jun 26, 2011 | 03:54 PM
Engine: 2.7L V6
Axle/Gears: 4.41
I'll bet the kinked fuel pressure line and rotted hose is your problem. Wait until you get that fixed before you go ahead and rip out the fuel tank.
Old Jun 26, 2011 | 03:58 PM
4g63's Avatar
yea thats i wanted to do i was going to replace the pump untill i replaced the filter.
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
