V6 Hesitation and Shutoff
Old Jun 24, 2011 | 06:16 PM
89Camaro88's Avatar
Car: 1989 Camaro RS
Engine: 2.8l V6
Transmission: Auto 4
I purchased a 1989 Camaro 2.8l v6 today and I need to figure out what is causing the following problem...
First off when cranking the car it hesitates as if there is no spark then after a few turns of the motor it starts fine... It idles fine but when the gas is pushed it bogs down a little then catches back up... but if I leave it idling to long it shuts off randomly...
I live in Sparks, NV if anyone around there wants to help me out...
Old Jun 24, 2011 | 07:29 PM
ex-x-fire's Avatar
Re: V6 Hesitation and Shutoff
Get yourself a GM fuel pressure tester, the connection is back by the distributor cap. The pressure should be about 36psi while the engine is running, & about 42psi when the engine is off. It should also hold pressure after the engine is off.
Old Jun 24, 2011 | 07:53 PM
89Camaro88's Avatar
Car: 1989 Camaro RS
Engine: 2.8l V6
Where should i be able to find one of those? and thanks
Old Jun 25, 2011 | 06:09 AM
ex-x-fire's Avatar
You should be able to get one for around $35 at the big chain stores like autozone, advance auto, ect.
Old Jun 25, 2011 | 03:37 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
I'd try cleaning up the throttle body as well, esp around the IAC.
Old Jun 25, 2011 | 09:36 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Possibly still running the stock Multec injectors? Lots of threads on them...
RBob.
Fanatic1074
Oct 3, 2022 05:57 AM
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
