aluminum heads for 2.8 v6
Old Jun 24, 2011 | 06:12 PM
mikeal8208's Avatar
Car: 1991 camaro RS
Engine: 3.4-3500 hybrid + Vortech V1 S-trim
Axle/Gears: 4.11 soon
Looking to cut weight and add cfm per cylinder before I put the money into porting and polishing a set I misewell start with the best I can... I know it probably means using a fwd top end but im not afraid of some fabricating... what vehicle to take the top end off of would be a great help...
thanks again, Mike
Old Jun 24, 2011 | 06:33 PM
project89's Avatar
Re: aluminum heads for 2.8 v6
ur forgetting that with the blower u will have to change out the pistons as well
besides that just look in the jy for anything with a late model 3400 ,3500 is out unless u start with a 3.4
what u have now is cheap with the blower, i say get it running as is and enjoy it ,and build a second motor on the side
Old Jun 24, 2011 | 10:40 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
3400 heads will fit on the 2.8/3.1 block, it's the 3500 heads that require the bore of the 3.4 block.
Any '96+ 3400, or 2000+ 3100 will have the top end you desire.
Old Jun 24, 2011 | 10:41 PM
Old Jun 25, 2011 | 11:38 PM
mikeal8208's Avatar
Car: 1991 camaro RS
I think ill start building a 3.4 and make it use the blower and the aluminum heads ill put up pictures as I go
midge54
Dec 27, 2019 04:14 PM
italiano67
Aug 31, 2015 06:04 PM
bdads
Aug 24, 2015 06:01 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
