damnit, still dies from heat, now **** ?
Old Jul 4, 2001 | 04:03 AM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
okay, so after driving for about 20-30 minutes in the 100 degree heat, i make a stop and when i try to start her up again, she still won't start. temp isn't over 215-220. hafta lift the hood, wait 10-15 mins, and then she starts up. thought it was the starter, replaced that last week.. . only thing is, i can start her if i turn the key and press down a little on the gas pedal.
Otherwise when i turn the key it doesnt make
a sound at all, just a click.
am i flooding or screwing something else up by doing that? what's wrong damnit~!
88 bird 2.8 auto mpi
Old Jul 4, 2001 | 07:07 AM
Glens89RS's Avatar
Car: 89 Camaro RS
Engine: V-6
Try checking the igintion control module. That was my problem last year.
Old Jul 4, 2001 | 10:13 AM
KED85's Avatar
Double check your wiring down to there, too.
It could be weak, somewhere.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Jul 4, 2001 | 11:41 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I would've said the module too; but he's not even getting a click out of the starter. Sounds like a cable (or connection) problem... but if all he does is lift the hood for 10-15 minutes and the car starts...
Try a starter heat sheild (or heat blanket).. it bolts to (or wraps around) your starter to keep it cooler. Or you could try a remote solenoid kit... 100 degree heat is rare around NJ, but we've had it a few times, and my car has always started fine.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jul 8, 2001 | 01:21 AM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Just thought I had to make a pointless comment here.. My car is the exact opposite. It runs like a beauty in extremely high temperatures...it's when it gets cold that it shudders and hesitates...never dies though..just doesn't put out.
Old Jul 8, 2001 | 11:33 AM
KED85's Avatar
Sounds like a few women I've known
It's a weak wire, because the voltage overheats it & runs the effort (to start car)
After wire cools down, it has a better chance to start the car.
Look at wiring at home.
IF it's ahevy duty appliance (iron, vqcuum cleaner) you have thick wiring.
Because that units produces lots of (wire heat) juice.
Using thick wire prevent a fire (wire melting & buring up).
Understand better?
I really think it's a lousy wire connection down there from Bubba, the mechainc!
Get under there, look, clean and give it a try.
You MAY win!
OR prove me wrong!!
Chat Soon,
KED85
Karl
sheachopper
Jul 31, 2019 11:27 AM
Gunner242
Dec 25, 2015 04:49 PM
Giocio
Oct 1, 2015 12:20 PM
Luigytico09
Oct 1, 2015 08:46 AM
