I think i have the crappiest engine!
Old Jul 20, 2001 | 08:09 AM
90_RS's Avatar
Ok i hve tried to find hiperformance parts for my car but i can't find jack!!!!!! everything i look for says its for tbi,tpi,or 305 engines. I have a 3.1 and i just want to add some horsepower , i know i don't have the best engine for performance but common!, even the wimppest honda has performance parts!SO does any1 have any suggestions for me ? And by the way what do you guys mean when you guys talk about "TB bypass"?????
Old Jul 20, 2001 | 09:23 AM
KED85's Avatar
There are many realistic ways to increase performance of these engines & have SOME fun!
THEN, the best is to start looking for a 1993-1995 3.4 block to swap in!
I did.
I hopped up my stock 2.8, I killed it & then swapped and all is good.
EXCEPT I KILLED MY TRANNY FROM THE POWER INCREASE
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Jul 20, 2001 | 11:02 AM
CHVYPWR's Avatar
Car: 1978 El Camino SS
Transmission: T-5 & 3.73's
<font face="Verdana, Arial" size="2">Originally posted by 90_RS:
And by the way what do you guys mean when you guys talk about "TB bypass"?????</font>
https://www.thirdgen.org/newdesign/t...ntbypass.shtml
Ya can't have too many fast Chevys!
Old Jul 20, 2001 | 11:47 AM
Jiffy's Avatar
<font face="Verdana, Arial" size="2">Originally posted by CHVYPWR:
</font>
Can You do that to a 3.1?
Jeff
92 Camaro V6, mods: K&N, modified air box, JET chip 2,high performance muffler.
www.camarors.4t.com
Old Jul 20, 2001 | 12:36 PM
Brian K's Avatar
No aftermarket for American Iron is all part of the philosophy I call selling out of America. You can do a few cool things to your 3.1 that will help.
I would get a Dynomax cat back and a Catco high flow converter. Then I would look into chips from Jet or Fastchip, and do not forget power pulleys from Jet and Hypertech. You can also get K&N Air Filters, MSD Direct replacement coil, MSD 6A Ignition box, Crrane 2030 Cam, 1.52 Roller Lifters, 3.73 rear gears and a locker or posi, and you can always run NOS. Also do not skip the free mods like disconnecting the TB Coolant lines… You can also clean your plenum and port it out, add a 160 or 180 thermostat and redline water wetter….. Consider synthetic oils, a shift kit and higher stall converter.
Old Jul 20, 2001 | 10:33 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Cant forget the TC lockup
Old Jul 21, 2001 | 12:58 AM
90_RS's Avatar
What is "tc lock up"?
torque converter???
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
