car wont start need help asap
Old Jul 6, 2011 | 01:17 PM
4g63's Avatar
i need help asap i have to be at work at 4 need to know if i could make it
so yesterday my car started i left it running for a short time i come back out side and its off tried to start it would not start so today i put some gas in it and it still wont start. before this while the car was running i think it has a bad fuel pump because evry time i went near half throotle and pass it dies out.....but i still hear the fuel pump turn on any ideas thanks
Old Jul 6, 2011 | 02:39 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: car wont start need help asap
We need more info....people ask this question all the time without bothering to mention whether or not its cranking, and if cranking, whether or not its at least firing and trying to start, if it doesn't crank is there a clicking sound from the starter attempting to turn it over etc. Try spraying some starter fluid into the intake tract and see if it starts, or at least fires if it wasn't firing before.
Old Jul 6, 2011 | 08:57 PM
4g63's Avatar
the fact that it was on before then just died out and all that i assumed you guys would know that its cranking but just wont start.... it sound exactly like how a normal car starts but it just dont start
Old Jul 26, 2011 | 12:59 PM
Ray the Rat's Avatar
Car: 2010 2RSSS
Engine: 6.2l
Transmission: 6-speed manual
Axle/Gears: 3.45
Distributor module, coil, fuel pump, fuel pump relay (check fuse) and/or connections to all these things are the usual suspects. I just had to replace the coil and module cuz mine died that way. It started up again after it cooled down, which might suggest the coil, but I replaced both to be sure. I now have the old ones in my tool/spares box that I carry in the car.
Right now I'm fighting the same thing. I repaired the transmission mount and replaced the gauge oil pressure sender and now the POS won't start. I've just started going thru the basics. I know I have spark cuz it started and ran when I poured a bit of gas into the throttle body. So it's a fuel problem. I just checked the fuel filter and I have fuel at both sides of it (not a positive test, but at least the lines aren't dry....I think I'll replace that cuz I have no idea how old/dirty it is, but it'll wait until I make a parts run.
I made sure that the oil pressure/fuel pump relay was securely fastened and it was. I even jumpered across the contacts of the connector which should cause the relay to energize and start the pump. (At least according to the electrical diagrams.) I dunno if it started the fuel pump, but the motor wouldn't start.
I guess my next step is to disconnect the output side of the filter and see if I get gas pumped through when I try to start the motor.
This is gettin pretty wearisome, cuz I've got a race car to finish for the salt flats in September. I only have 48 more days to do it.
RtR
http://www.chevyasylum.com
Old Jul 27, 2011 | 08:45 PM
Car: 2010 2RSSS
Engine: 6.2l
Axle/Gears: 3.45
After a couple of hours going thru the schematics, I found a reference to "Inline Fuse Number 3." I remembered seeing fuses near the battery when I was checking fusible links. Sure enough. Twenty amp fuse was blown. Now I know why you shouldn't run a jumper across the oil pressure fuel pump sensor. That circuit is hot all the time and the pump will run even when the IGN is switched off.
4g63, you may want to look at those fuses...right near the passenger side fender, close to the battery.
Just an aside, A friend came to help me with the race car today and we got it ALMOST to the point of firing up. A little more wiring work with the ignition box and we'll see if the motor will live or die.
BlueIroc-Z
Jun 9, 2019 03:22 AM
9192camaro
16
Feb 3, 2019 12:21 AM
Wade787b
Sep 29, 2015 01:15 PM
L98GTA87
Aug 5, 2015 11:02 PM
