How would i change...
Old Jul 23, 2001 | 12:24 AM
CamaroVroom's Avatar
what would i need to change if i had a vacuum leak and how would i change it???
Old Jul 23, 2001 | 02:34 AM
HIX5000's Avatar
Depends on where the vacuum leak is. How do you know you have a leak?
Old Jul 23, 2001 | 11:01 AM
KED85's Avatar
When i did my 2.8->3.4 swap, i spent awhole day n vacuum hoses.
I had to replace one "T" section (and lots lots lots of rubber hoses.
I ended up using 5/16" windshield wiper hose.
One hose, the one at the back of the engine by distb, base, I ended up using a 1/2" with LOTS of electrical tape, to take up slack/sapce.
That said, I have no leaks, all connections right and tight and I have very high solid vacuum readings.
I got everythign from a local auto parts store.
IT was just VERY time consuming.
Everytime I touched a plastic piece, it cracked.
The stuff is very fragile.
NOW, I am finishing off my 1985 S-10 Blazer 2.8 engine. FOR THAT PROJECT, I have removed every hose I can.
I just passed smog, so I have 1 1/2 years to reattach every hose, etc.
AND I WILL.
But, I need to get it running and I removed ALOT & PLUGGED UP alot.
For these fuelie cars, it's mandatory to make every vacuum hose correct and proper routing for peak efficency & max operation & best gas milage.
In other words, take the time, do it right. Myy truck engine, I can cheat.
New tech, verses old tech. My truck is carb'd.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Jul 23, 2001 | 07:21 PM
well the vacuum leak is the last resort...the car runs fine for a few minutes then it is about to stall when i'm stopped not in park when i'm in gear..so the vacuum leak is the only thing that i haven't checked or replaced....
Old Jul 24, 2001 | 12:21 AM
mAjInRS's Avatar
so many people have had this problem and there's so many different answers as to what it could be, i personally found out that it wasnt vacuume...vacume...vacuum..baaah, anyways my problem was with the knock sensor(ESC) i just unplugged it and know she runs fine and doesnt die anymore, i dont know of any long term effects this might have but none have surfaced yet *knock on wood*
91 Blue RS with ASCD SS hood w/hood pins, Flowmaster 80 series w/3 inch dual exhaust, K&N, Hypertech Power Chip, Bosch Platinum wires and plugs.
Soon to be added:
Z28 spoiler.(to compliment the ram air hood)
New paint.(black with orange stripes)
A 3.4L V6.(WOOHOO!!)
Old Jul 24, 2001 | 12:34 AM
i've never heard of a knock sensor in my life!! esc??? doesn't seem to be anywhere in the repair manual???
carlos64030
Jan 22, 2025 03:31 PM
deadbird
Aftermarket Vendor Review
26
Mar 9, 2016 10:56 AM
BlackTopKing
May 13, 2014 09:53 PM
BowtieLife
Feb 11, 2013 09:36 PM
