1982-1984 2.8 power recipe
Old Jul 23, 2001 | 09:13 PM
V6camaroman's Avatar
2.8 block bored .030 over
complete engine rebuild kit
push rod and rocker arm kit
high volume oil pump
edelbrock camshaft kit #3790
edelbrock intake manifold base #3785
edelbrock intake manifold top #3789
double roller timing chain
weiand water pump
1" carb spacer
edelbrock 600cfm carb
flowtech headers
edelbrock valve spring kit
accel superstock plug wires
accel superstock coil
accel cap&rotor
k&n air & oil filter
manley intake & exhaust valves
port and polish heads
Old Jul 23, 2001 | 09:47 PM
KED85's Avatar
Here's what ya do & save 90% of your time.
Go get 1985 & above MPFI heads.
Rebuild them & new guides.
Go get same cam from that style (MPFI 2.3/3.1) engine
Rebuild distributor Hop up ignition, new coil.
Rebuild carb
THEN FOR FUN!
Go get a spare 2.8 regular intake (from a S-10 Blazer if ya wanna, CHEAPER)
Go get a Holley 500CFM 2-bbl.
Modify the factory intake for the Holley.
Grind down space between the openings and drill four new holes.
Instant Edelbrock intake!
Edelbrock is only for switching the tops (carbs), has no true gain at all over stock intake. This is what GM recommends, too.
That's what I've done to my truck engine.
Once it's better (I have to swap oil pumps now), it'll run stronger.
You can get all this stuff from the yards for cheaper than it'll cost ya to buy the Edelbrock intake set up (about $250.00-ish).
Buy gaskets at 800-831-0884 Norhtern Auto Parts.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Jul 24, 2001 | 12:10 AM
WaynesRS's Avatar
thats one mean a** V6 motor !
Wayne
Old Jul 24, 2001 | 02:09 AM
nothingssafe's Avatar
Car: 86 TA
my 88 i have had up to 120 or more(115 speedo) and it has never slowed or shut of. what the hell kinda gov is it?
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
E Rod
Aug 28, 2015 05:17 AM
sailtexas186548
Aug 24, 2015 10:11 PM
