At wits end, need help
Old Jul 24, 2001 | 09:37 PM
PerroneFord's Avatar
Help guys! I have tried EVERYTHING I can think of to get my Camaro running properly and I don't know where to turn.
I have a 1982 Camaro, 2.8. The care idles pretty well, but sputters and bucks anytime the engine is under load. Its basically undriveable.
I have replaced the carb with a new unit, replaced the coil, cap, rotor, distributor, plugs, plug wires, re-timed the car properly, changed the fuel filter, and I don't know WHAT to do next.
I'd be grateful for any nuggets of wisdom on this one. Any clue on where to get a new fuel pump? This is my next course of action unless someone here has better ideas.
Thanks in advance
-P
Old Jul 24, 2001 | 09:53 PM
breathment's Avatar
Ahh, any codes? Maybe have something to do with ur fuel pressure maybe. Or your ignition modual. Maybe its something internal. do a compression check.
88' GTA 350 MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass
Old Jul 24, 2001 | 10:09 PM
Forgot to mention compression check showed fine. I don't know about computer codes since I don't have a scanner. Which one would be appropriate for a 1982 model?
-P
<font face="Verdana, Arial" size="2">Originally posted by breathment:
</font>
Old Jul 24, 2001 | 10:46 PM
breathment's Avatar
CAn't u just jump the A and B terminals and watch the flashes, or do u not have the 12 Pin diag. port?
88' GTA 350 MODS---&gt; air foil, K&N, Shift Kit, 180* therm, TB bypass
Old Jul 24, 2001 | 10:59 PM
KED85's Avatar
YOU DO NOT HAVE A COMPUTER,
You have a federal LB2 engine, same as my 1985 S-10 Blazer.
I would let someone one else work with it.
You have done everything right!
Be there, when they diagnois it.
Yo have done everythign right.
I just did this to my S-10 Blazer (rebuilt carb & distriB). All I need do now is change oil pumps & I should be ok!
Engine oil pan was full of water from head gasket. Big deal at 211,500 miles. I made it live again, that's all I care about. I'll change blocks one day. That truck tranny is next!
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Jul 24, 2001 | 11:11 PM
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
my car was doing something like that a couple of months ago, try checking around for vacuum leaks
J-money
Jan 4, 2019 09:45 AM
92projectcamaro
Jan 18, 2016 08:00 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
dbrochard
Sep 7, 2015 09:41 AM
SG91camaro
Sep 5, 2015 10:27 PM
