v6 intake, 92 RS
Old Jul 12, 2011 | 12:05 PM
jederlache's Avatar
Car: '92 Camaro RS
Engine: 3.1 MFI V6
v6 intake, 92 RS
So a friend of mine has a late model bird with a v8, he attached a K&N filter right onto the intake above the serpentine belt. Does anyone know of a filter i could do the same with?
Pictures would be awesome, i'm not mr. mechanic and pics help me identify what i need.
Thanks guys.
~Dom
Old Jul 12, 2011 | 05:51 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: v6 intake, 92 RS
really the best for looks and preformance in my mind is going to a junk yard and finding a dual snorkle intake off a 80's camaro.. i bought one for 15$$ and it bolts right in and looks great.... itll supply enough air for any v6... just my opinion though...the intake is black now just to you dont say...jezzz that red looks dumb..
Old Jul 12, 2011 | 07:56 PM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
The dual snorkel intake is a cold air intake that most of us v6 camaro owners are fortunate to have. By putting a filter right at the TB you would be sucking hot air into the engine creating a decrease in performance.
Old Jul 12, 2011 | 09:01 PM
bigblack92's Avatar
Car: 1987 Camaro LS swapped, brembo brak
Engine: 2006 5.3
Transmission: 2009 AR5 from Chevy Colorado
Axle/Gears: Stock from 1999 Z/28
Thanks for that info will have to look at PnP this weekend for 80ish cars.
Old Jul 12, 2011 | 09:53 PM
fasteddi's Avatar
Car: 1991 Camaro RS
just remember when you put it in that your gonna need either the black tube that has a MAF sensor in it or make on out of pvc..remember 3.1l have no MAF sensor we have a MAP... for the gap between the rubber houseing that comes off the throttle body to the dual snorkle ...you can see it on the pic i put up.its the hard plastic tubing.. thankfully i found a 88 camaro that basically had the whole engine intact so i just picked what i needed...your also going to have to extend your air sensor that is in yout factory air "canister" ...just extend the wire... its totally worth the 30 min it takes to hook everything up...and it looks good too!!!!
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
