Question on the 3.1
Old Jul 29, 2001 | 01:08 PM
grouper's Avatar
Question on the 3.1
Iam trying to figure out a few things for my buildup. Now is the 3.1 and 2.8 are the same motor but the 3.1 has a biger crank in it????? if so is ti a 3.4 crank. also will parts for a 2.8 or a 3.4 fit right in a 3.1 iw as told by some **** at paw that the aluminum heads for a 2.8 wont fit but i think he was smocking crack.
Thanx in advance
Old Jul 29, 2001 | 01:24 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
who told u that at PAW? i used to work there so i can go and smack him upside the head. The 2.8, 3.1, 3.4 all have the same block, 3.4 and 3.1 are bored and stroked...
1989 Firebird
2.8 v6, t5 swapped in
Performance Mods:
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil, Accel 8.8 wires, Auto Meter Gauges (Water, Clock, Fuel Pressure, and 5" Sport Comp Tach)TB Bypass, 4th Gen Seats
Car Stereo:
Blaupunkt head, Monster Cable wiring, MTX Thunder 6000 12" inverted in a personally made box with a 350*1 Amp pushing it, MTX 6x9 in the back with hopes for components in front
Coming for my v6:
Panhard Bar, 4thgen front seats, Nitrous, Line Lock, Posi, Spohn Torque Arm & Subframe connnectors
"I'd rather run last in a full out race, than to NOT have run at all"
#3 Forever
My Site:
Click Here to see my car!
Old Jul 29, 2001 | 07:12 PM
grouper's Avatar
thanx for the info,,
does anyone have the bore size and other number for the 3.1
also if it is stroked what sizr crank is it, kinda lost on that part a 400 with a 350 crank is a 383 but with a v6 iam confused.
thanx again in advance
Old Jul 29, 2001 | 10:27 PM
KED85's Avatar
Graeme, you cannot bore out a 3.1 to make a 3.4.
We finally figured that detail out. I can pull up the specs from the GM books, too.
The 3.4 block is meatier and the internals are different. Using 3.1 internals does not make a stroked 3.4. You can get that "kit", but, why pay for that when you buy the correct 3.4 engine and have more room for the rebuild one day.
The heads, yes are same (as are the valves), but the springs and the retainers are different.
WHY ARE THE ALUMINUM HEADS DIFFERENT?
The valves for the alum. are splayed, like a Chevy Big Block.
Our iron heads valves are side by side.
Thus they FIT, but will not interchange intake systems.
It wasn't our decision to be stuck with the cast iron heavy heads! I'd like the alum. heads, myself, too. I had a pair for free, I tossed them back to the pile of heads.
https://www.thirdgen.org/messgboard/...ML/001462.html
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
the_nikfive
Aug 11, 2015 02:46 AM
guy76767
Aug 6, 2015 05:58 PM
