Handling?
Old Jul 29, 2001 | 06:16 PM
bad85z's Avatar
Handling?
What are some things I could do on a budget to make my Camaro handle better?
Bandit
1985 Sport Coupe Z-28; 2.8L V6; T-tops; Tail-light Covers; Spoiler
Old Jul 29, 2001 | 10:19 PM
KED85's Avatar
GO GET A Z-28 suspension from the wrecking yard. Or a WS-6. Including the shocks. Sway bars are almost free in the yard. Try that in the aftermarket world!
My car has the F-41 suspension package. My sway bars are thicker than a 1990 Z-28. I got real lucky!! My shocks have 110,000 miles on
them and very very good ride!
It's better tires that I am weak on and I do want a SFC (sub frame connector). My car flexes like a girl without a bra
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Jul 29, 2001 | 10:27 PM
92_CamaroRS's Avatar
Do the stock RS come with sway bars?
My had front and back when i bought mine.
Old Jul 30, 2001 | 09:04 AM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
They come with sway bars, but they're tiny compared to the Z28 or WS6 bars. I switched from the factory RS bars to WS6 ones. What a difference. It feels like I have 2 extra tires under the car!
'91 RS 3.1
SSM SFC's
Energy Susp. Hyper-flex kit
GTA Sway bars
Clarion, Phoenix Gold, JL Audio, etc.
Quote "If you can't beat them, arrange to have them beaten."
- George Carlin
Old Jul 30, 2001 | 09:49 AM
CODY BEHNKE's Avatar
Don't buy just the sway-bar and shocks, you need the sway-bars and the springs thats the main difference on WS6/Z-28/F41 equipped cars then buy some good shocks elsewhere ( KYB, bilstien )
Old Jul 30, 2001 | 10:12 AM
87_Camaro's Avatar
does a Camaro Sports Coupe come with sway bars???
Old Jul 30, 2001 | 11:11 AM
KED85's Avatar
ALL modern cars have "sway bars".
Some are a different type, that others.
I did not include the springs as they are a pain to remove.
IF one is not happy, after doing all that conversion work, then ya can get newer springs with the money saved by using wrecking yard stuff, already.
That was my reasoning behind my thoughts on this.
IT SEEMS every car has all the parts for that conversion upgrade idea (holes to mount sway bars). The Z & the WS stuff also have poly end link bushings (on sway bars), too! GRAB THOSE ALSO!
Chat Soon,
KED85
Karl
Old Jul 30, 2001 | 12:46 PM
Brian K's Avatar
I would get lower control arms. $77-150 Then I would get a panhard rod $99, then a urethane bushing kit, 139....
Old Jul 30, 2001 | 03:34 PM
Camaro_hunter_d's Avatar
I paid 75 bucks for a set of Iroc sway bars... Its handles great with that alone. I am planning on getting the car lowered 1.5-2 inches. that will help too... still tring to find a good set of shocks/struts.
Old Jul 30, 2001 | 05:33 PM
Brian K's Avatar
Some things I have done, I ahve begun Urethane Bushings... Nice change, cause they are new and not cracked and worn out, then a wonder bar, that was nice and only 15 bucks, and reduce some of your cars weight...
Old Jul 30, 2001 | 05:41 PM
bad85z's Avatar
Thanks. I am going to check with the salvage yard and see what they have. Thanks!
Bandit
Old Jul 31, 2001 | 08:54 AM
KED85's Avatar
Support your local wrecking yards.
They are the ORIGINAL RECYCLERS!
Make sure you buy every little piece, even the ones you think you may not use. Extra nuts and bolts always come in real handy.
Chat Soon,
KED85
Karl
1992Z28!
Nov 19, 2015 07:33 AM
Numbah-1
Oct 2, 2015 08:27 AM
ndndndnd
Sep 28, 2015 08:00 AM
roysatikas
Sep 22, 2015 08:15 PM
apie2546
Sep 20, 2015 01:03 PM
