ENGINE TEMPERATURE?
Old Aug 13, 2001 | 07:20 AM
Leonardo carrasco's Avatar
ENGINE TEMPERATURE?
Last month I bougth a Blazer 1992. I want to know which is the v6 running temperature, becouse when I am driving in the city or in the highway the engine temperature is around 210F. Is the engine temperature normal or not?
Thank you!
Old Aug 13, 2001 | 12:21 PM
KED85's Avatar
That is very proper temp. Mine generally runs 195 until it reaches AC usage & hills.
You're fine.
Check hoses!
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Aug 13, 2001 | 12:22 PM
Kevin S's Avatar
Sounds fine.
My RS ran like that in town and cruising the highway the temp would go up and down between 220 and about 185.
I set my fan up with a toggle switch to run when I want it too.In town it stay around 180 unless I have the air on.On the highway it's the same.For some damn reason the temp will raise with the air on and will not cool down untill I stop.I can let it idle for a few minutes and it cools down.But as soon as I start moving it starts climbing.I'm thinking of buying a dual fan kit.Hopefully that will help.
The next time you think your perfect,try walking on water!
[This message has been edited by Kevin S (edited August 13, 2001).]
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
