no brakes
Old Aug 15, 2001 | 01:31 PM
nothingssafe's Avatar
Car: 86 TA
no brakes
ok well i do not have any brakes. they go almost all the way to the floor when i hit them. then the brake light comes on. only the rear brakes are engaing, like i was pulling up the parking brake. i just replaced my master cylinder and booster. also my pads and shoes are fine. any ideas?
1988 Camaro
2.8 with T5
K&N
Soon to be CAI or Ram Air...
http://www.nothingssafe.com
Old Aug 15, 2001 | 01:35 PM
Ovrclck350's Avatar
make em bleed
Old Aug 15, 2001 | 01:37 PM
Car: 86 TA
already did...
1988 Camaro
2.8 with T5
K&N
Old Aug 15, 2001 | 01:59 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
mkake em bleed fully, drain entire system & put in fresh fluid.
Old Aug 15, 2001 | 03:42 PM
KED85's Avatar
Bench bleed the M Cylinder?
IS IT seated correctly?
Then ya need to bleed again.
Honest.
I discovered that naswer, too.
When I KNEW I did it correct, I DID, but, the system didn't cooperate.
Bleed.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Aug 15, 2001 | 08:00 PM
CD MaroMan 91's Avatar
i'm having the EXACT same problem with my '91 RS!!! my dad is fixing it today though... bleed!!!!!!
(orignally CDnAP48)
'91 Camaro RS (in readers rides)
Dark Metallic Blue
V6, 4th Gen Seats, Sony Xplod CD Player and Sony Xplod 6x9's, 2 RF Punch 12's, RF Punch Amp, Custom Made Black Carpeted Box, Kelly Charger Front Tires. Soon to come, New Rims, New Rear Tires, Carpet, Floor Mats, Paint Job, Interior Color Change.
E-mail me for any questions or comments.
AdidasPredator15@jam.rr.com
http://www.geocities.com/adidaspredator21/index.html
Old Aug 15, 2001 | 11:16 PM
3.1 firebird's Avatar
If the calipers are getting fluid and your brakes are bleed ....I;m thinking the proportion valve may be damaged.
Old Aug 15, 2001 | 11:30 PM
KED85's Avatar
ONLY WAY THAT IS DAMAGED IS IF IT LEAKS.
Chat Soon,
KED85
Karl
Old Aug 16, 2001 | 10:32 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You replaced the m/c, eh? If you bench-bled it correctly, you might have gotten a bad rebuild. Bring it back, and try again. My rear axle swap (drums to disc) took forever because of a bad master cylinder. I had no pedal, and always got the BRAKE light, no matter how many times I bled the f%#$ing master cylinder. I spent a week on the damn thing. I finally took it back to get another rebuilt one (rebuilt by A1 Cardone); it took a day to come in, but when it did- I was driving the next day.
I was even raising the back of the car up verrry high to make the m/c body (not reservoir, the body) LEVEL with the ground, and bleeding the original "bad" m/c- no good. What a pain in the butt.
I still think I have air in the m/c... I have a feeling my pedal could be higher. If I try a powerbrake, I'll see the BRAKE light come on. I was designing a home-made pressure bleeder (using my "shop" air compressor), but completely forgot about the project. I was able to make the pressure bleeder to act on a single brake line, but the m/c one requires a bit more work. Anyway... it sounds like the master cylinder.
Do you know about the quick-take-up valve? That thing affects the bleeding procedure...
-Tom P (Hot rodded 1986 Firebird 2.8l)
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
