porting and polishing
Old Aug 12, 2001 | 07:42 PM
WaynesRS's Avatar
how much does it cost to ?
1. polish and port heads
2. " " itake manifold
3. throttle body
Thanx , Wayne
Old Aug 12, 2001 | 10:27 PM
KED85's Avatar
How about asking some people that prepare their cars for NASCAR or local racing circuit.
AND best if ya can find a spare set to beef up, while your car is in one piece.
I'd like to know, cause I've spent 10 hours on one V-8 head. I want to know what my time was worth. Three more heads to go, also!
These V-6 don't need much work beside new valve guides, new springs and retainers (part numbers 12363215 & 12362316).
Already got the bigger valves and better flow design.
Don't forget to add gasket set cost.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Aug 12, 2001 | 11:19 PM
WaynesRS's Avatar
Thanx Ked , I was thinking about getting another set of 2.8 heads out of the junkyard .hmmm wonder how much they would cost ? Or could i put 3.4 heads on there or even 3.1 heads, If I could , would there be any benefits ?....how hard is it to port and polish ....Thanx , Wayne
Old Aug 13, 2001 | 05:40 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
yeah, i've been wondering about this myself.......how much would a compatent machine shop charge to port and polish my heads and my intake manifold?
Old Aug 13, 2001 | 10:50 AM
KED85's Avatar
GET THE LATEST FREE HEADS YA CAN.
If ya score 2.8 for free, great
IF ya score 3.1 heads for free, ya score.
Either way MAKE SURE they are MPFI heads.
AND GO TO GM DEALER AND GET THE GM PEERFORMANCE PARTS BOOK. Best $6 you can invest in.
AND page 136 has the pics of the aluminum heads and WHY you cannot use them on the F body cars.
Again, I paid $800 for a running perfect 3.4 40K mile long block (others have paid less for a 3.4, too). Add $100 for gaskets.
Figure same physical effort for both jobs.
I want to see a cost comparision to this port & polish question.
As my swap did/has all this stuff, already (better heads (springs/retainers/cam).
Chat Soon,
KED85
Karl
Old Aug 13, 2001 | 01:51 PM
WaynesRS's Avatar
Thanx for all your help Ked , I assume your meaning free flowing , meaning flowing better , I wish could get some free heads , hehe , in my dreams .Im thinking of going to U-PULL IT junkyard , where its cheaper cus you pull the parts yourself and you deal with them on price .I know I wont have any trouble finding any , there has got to be wrecked camaros there .The only V6 heads I could not use out of those cars would be the 3.8 heads right ? Im not doing the 3.4 swap because I have a new 2.8 in it with less than 10k miles on it .When I made the swap I was just thinking 350 , but it was going to take to long and cost to much , so I setteld for another 2.8,its not bad though at all , I know the 3.4 is much better though .Any other parts you know of that can be swaped on the 2.8 from other cams that will benefit ? ...Thanx for all your help Ked , and anyone who replys
Old Aug 13, 2001 | 01:54 PM
WaynesRS's Avatar
I couldn't use 3.4 cus there aluminum right ? hmmm
Old Aug 13, 2001 | 02:30 PM
x55Cam's Avatar
Car: 1989 IROC Camaro
Engine: 5.7L
Wayne, porting/polishing heads/intake ( including competion valve work and resurfacing) costs about $950 depending on where you go. If you want more info I'll be glad to help you out.
[This message has been edited by x55Cam (edited August 13, 2001).]
Old Aug 13, 2001 | 02:55 PM
WaynesRS's Avatar
Thanx so much for your help X55cam I was thinking sence it cost that much , Just starting with the heads .Maybe it would be cheaper to get some heads out of the junkyard and take them to a machine shop , So I would not have to pay them labor to take them off and put them on . My friend can install them for me .Think this would be cheaper man ? plus I can buy the heads , then when I get more money p and p them Wayne
Old Aug 13, 2001 | 04:12 PM
x55Cam's Avatar
Engine: 5.7L
Try looking for heads from 93-95 Camaros with 3.4L. You'll stand a better chance of getting ones that are rebuildable.
I've already extablished a minimum of 20hp gain using some software that takes data from flow benching BUT, you'll have to chuck the stock throttle body for a better flowing one that will take advantage of the port work. Otherwise it'll negate or the P/P you'll be doing.
Old Aug 13, 2001 | 05:18 PM
WaynesRS's Avatar
X55CAM ,
Thanx so much man , Its so great to get a hp number like that , now I kmow it will be worh the money and time and will want to pursue this project THANX Wayne
Old Aug 13, 2001 | 10:05 PM
WaynesRS's Avatar
X55CAM , what size throttle body should I get ? ..thanx , Wayne
Old Aug 13, 2001 | 11:27 PM
KED85's Avatar
Try pricing this part number
14054884.
NEW GM 2.8/3.1/3.4 heads.
These are from the 3.4 engine, I have under my hood, now.
Chat Soon,
KED85
Karl
Old Aug 14, 2001 | 08:24 AM
x55Cam's Avatar
Engine: 5.7L
Wayne, you can try the Fieo store :
http://www.fierostore.com/pegasus/index.html
Whom sells a big bore TB $200 w/core. I'm not sure what size it is, you'll have to give 'em a call. The one I have is a 62mm type that I got from a guy in Finland that sells them for about $160. I can send you pictures if you'd like. It requires that you transpose some parts from your old TB to the new and it eliminates the need for the coolant lines.
Old Aug 14, 2001 | 08:54 AM
KED85's Avatar
Hi X55Cam
I viewed the Fiero Store pages.
REAL CURIOUS.
3mm is going to MAKE that much difference?
I CAN understand IF there was an air splitter in the way, as is with the V-8 Throttle bores.
May I see a pic, Please?
I'd like to recreate that throttle bore increase in size. It should be kinda easy.
Those throttle bores are a dime a dozen at the wrecking yards. Then I can score the Fiero valve covers, too. Only wish I had them when I swapped engines.
Those engine kit prices are way high. I paid $800 for acomplete running engine with no machining costs.
The Accel coil, I just bought from Kragen for $36.
I LOVE FIEROS. One of my Favorite rides.
Chat Soon,
KED85
Karl
Old Aug 14, 2001 | 09:15 AM
WaynesRS's Avatar
Yeah , I like thos fieros to .My neighbor just got one , it looks like brand new . I can't belive he got it in that great of shape. It's silver and sounds like it has flowmasters on it ....Thanx for the help again guys , well be checkin out those parts.That's a good price on that throttle body , I saw one somewhere else (62 mm) for $200 and I thought that was kinda high. I'd like to see a pic of that throttle body X55Cam ,Thanx Wayne
Old Aug 14, 2001 | 10:56 AM
WaynesRS's Avatar
Ked ,
I looked up that part number you gave me for the 3.4 heads , $408 thats not to bad of a price .Im thinking though if I find some in the junkyard ,maybe I can get them for around $200 .But I might just go ahead and get the new ones .Wayne
Old Aug 14, 2001 | 11:00 AM
3.1 firebird's Avatar
check out NuTek racing. They have 3.4 heads with performance options.
Old Aug 14, 2001 | 01:35 PM
x55Cam's Avatar
Engine: 5.7L
KED, it seems that the Fiero Store TB is a bit smaller than mine. Mine measures 68mm/2.7" at the bore. The stock GM one measures 52mm/2.0625". When I insert these numbers to the analyzer, CFM ratings jump from 337 to 819! The stock unit has to be removed to measure it accurately. I can post the photos here on the board tomorrow as I don't have acess to my web at this time.
3.1firebird, NuTek use to be Norris Racing, correct? They certainly know how to work up the 3.4L. I almost went to them for my work, but found a local shop. I think they dynoed a 3.4L Camaro at 115rwhp and after all the engine work managed something near 170rwhp, within street specs. Thats well over 200hp at the flywheel!
Old Aug 14, 2001 | 06:21 PM
WaynesRS's Avatar
do ya know what Nu tek's racing website is ? Wayne......thanx
Old Aug 14, 2001 | 07:14 PM
KED85's Avatar
What was the foundation of your throttle body?
Fiero?
FBody
FWD 2.8/3.1/3.4?
THAT IS A MONSTER OF A SIZE INCREASE!
Must be able to increase the air flow to the engine ALOT (then ya need this size increase) to warrant usage of that size you've got.
I do agree 337cfm is way small for this V-6.
But how much air can ya ram in? For my Firebird, not much at all.
Those NEW heads MAY be a wise choice.
Figure cost of cores from yard
Figure new springs called out in GM Perf. Parts Book, along with retainer, machine work for new valve guides.
I'll be you can bargin those new heads down abit.
Our 60 Degree V6 looks like the throttle bore for the New Corvettes, one large air inlet, unlike the two blade inlet of the past 80's-90's Corvette.
Chat Soon,
KED85
Karl
Old Aug 14, 2001 | 07:20 PM
WaynesRS's Avatar
Ked ,
It is 2.8 mpfi camaro , Is that what you mean by foundation ? What size throttle body you recomend ? Thanx , Wayne
Old Aug 14, 2001 | 08:51 PM
x55Cam's Avatar
Engine: 5.7L
Here's one pic that shows the TB in a car (not mine). The parts labled A/B/C are the ones transfered from the stock unit.
These TB's will compliment the port /polishing/head work that is done to the stock unit, if thats what you mean by 'foundation'. They are made to take advantage of the P/P work, otherwise it would be almost a total waste of time and money to just replace the stock unit, alone. In actuality, the total CFM including P/P amounts to about 790 CFM so the intake/head combo is really restricting the TB. The weakest link is the upper and middle intake based on the Flow Bench data.
Old Aug 14, 2001 | 09:24 PM
WaynesRS's Avatar
Awesome , Thanx X55cam , is that a 62mm or a 68 ? ..Wayne
Old Aug 15, 2001 | 07:56 PM
x55Cam's Avatar
Engine: 5.7L
<font face="Verdana, Arial" size="2">Originally posted by WaynesRS:
Awesome , Thanx X55cam , is that a 62mm or a 68 ? ..Wayne </font>
It measures 62mm/2 7/16" at the flange side. The opening is about 2 3/4"
Old Aug 15, 2001 | 08:31 PM
WaynesRS's Avatar
Thanx X55Cam ...hmm I was just wondering would these heads work with Cranecam 2030 or would I have to use a different cam ?
Old Aug 15, 2001 | 11:26 PM
KED85's Avatar
That is a fine looking piece of machining.
Is this a car you know of (friends) or apic you found.
The foundation I was referring to was, what design of the throttle body? A FWD or a Fiero or a F body car.
This guy made the housing and sold it for $170? Fair deal.
Chat Soon,
KED85
Karl
Old Aug 16, 2001 | 10:53 AM
x55Cam's Avatar
Engine: 5.7L
Ked, I know that the maker of this owns an F body 3rdGen but he didn't specify that the TB can only be used in certain 2.8/3.1/ cars. I would think that this unit can be used for any car that uses a 2.8/3.1 intake. Though a Fiero's upper is slightly different, for example, it should fit since the length of the TB is almost exactly the same as the stock unit, maybe slightly longer, but I would have to take some measurements to verify this.
Old Aug 16, 2001 | 12:49 PM
WaynesRS's Avatar
Ked , its an F-body , 88 camaro 2.8
Old Aug 16, 2001 | 01:48 PM
Brian K's Avatar
We should do a GP on this... 125 a piece....
Old Aug 16, 2001 | 07:28 PM
KED85's Avatar
That is a nice bit of maching work. I do agree with ya about the actual real world usage.
Would you think that guy would let go of these for a buck and a quarter?
Chat Soon,
KED85
Karl
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
bigjay89gta
Oct 15, 2015 08:04 AM
Reid Fleming
Oct 10, 2015 09:56 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
