Will the car turn over if the Pass Key Module is bad?
Car: 1991 Z28
Engine: 5.7 TPI
My car will turn over, but not fire. Is that the VATS by any chance? My mechanic says I have no spark, so he is changing out the VATS... or is he wasting his time?
Car: check
Engine: check
Transmission: check
Re: Will the car turn over if the Pass Key Module is bad?
VATs won't affect spark, just the starter and the firing of the fuel injectors. May want to find a different mechanic.
Odds are it is first the ICM, second the pick up coil, third the ignition coil.
RBob.
Car: 1991 Z28
Engine: 5.7 TPI
If he can't fix it, I'm not paying for it! I told him I am not paying him to learn how to fix cars on my dime...
Car: check
Engine: check
Transmission: check
When I grabbed one from the JY I found a car with the windshield already removed and the dash pad gone. That made it much easier to get the VATs module out.
RBob.
3rdgenparts
Aug 6, 2015 09:03 AM
