front Struts
Old Aug 19, 2001 | 11:13 PM
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
front Struts
Is it possible to do change my front struts in my own driveway in stead of going to a shop??
Rob
Chevy 2.8L 60° V6
Mods:
•K&N Filter Lid
•87 Formula Hood
•Bosch Platinum +4
•Hi-Flo CatCo CAT
•Flowmaster 80 Series Muffler
•83 Trans Am 15x7 Turbo Fin Wheels
•B.F.Goodrich Radial T/A 225/60-15
•Chevy 2.8L Heddman Headers (Going on soon)
http://www.geocities.com/fiream/RobsCarArtPa.html?994187591828
Old Aug 20, 2001 | 12:17 AM
BitchinRS's Avatar
That depends.
On one hand if the front springs are seprate from the struts it is no problem. Simple follow the instructions type deal. Just read the instructions in the Haynes manule. On my '92 RS it was a breaze. Took and 2 and half hours do to a bolt the refused to come off, but my struts were bad for about 5,000 miles. So it's no wonder I ran into a little difficulty.
If the springs are around the struts life gets a little more difficult and cause bodily harm. If the springs are around the sturt you will need a spring compresor inorder to remove. In this case I would just take them to have them done. The thought of one of those srpings flying off and smacking me the head is scary.
HTH
Old Aug 20, 2001 | 10:53 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yep, it's possible, but you will need an alignment afterwards. Also, you should use a torque wrench- this is one part you don't want to "guess at" bolt tightness. The lower strut-to-knuckle bolts are spec'd for 200 ft/lbs.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Aug 20, 2001 | 11:15 AM
fiream's Avatar
Engine: 400HP 350
Okay so it should be pretty easy, I checked it out and my spring are not around the struts.
Thanks Guys
Rob
Chevy 2.8L 60° V6
Mods:
•K&N Filter Lid
•87 Formula Hood
•Bosch Platinum +4
•Hi-Flo CatCo CAT
Old Aug 20, 2001 | 02:24 PM
Brian K's Avatar
I bought my KYB Struts and paid 20 bucks for a local shop to install them.. They guy did it on his break for cash.... Worth it cause I was tired of doing hard work after a day of work...
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
NORTz89
May 20, 2020 03:51 PM
Polo Z03
Wheels and Tires
49
Jul 21, 2017 12:31 AM
redmaroz
Apr 25, 2017 07:14 AM
