losing or gaining hp/torque with converter gutted ?
Old Sep 8, 2001 | 07:22 PM
WaynesRS's Avatar
Most of you prabably have heard me say my converter is gutted .I have heard that it helps and I have also heard you loose horsepower .Or do you gain high end torque and loose low end or neither .When I gutted mine I noticed it was a little bit faster but it may just be in my head you know .Do you think I would flow better with a high flow converter ? or just leave it as it is .I do have a dynamax muff and I know when I put that on there I felt an increase in horsepower so I dont want to loose it if I decide to get a high flow cat .Thanx for your input guys , Wayne ...88 rs camaro 2.8
Old Sep 8, 2001 | 07:37 PM
Camaro_hunter_d's Avatar
well... It can help yes. And it can hurt. I have said many a time that a too free flowing exhaust robs power before but... Too free a flowing can rob torque like a theif.
Old Sep 8, 2001 | 08:39 PM
Brian K's Avatar
With my cat gutted I seemed to pull much better over 70MPH, much better, but below 70 the umph ithad seemed gone...
Just my opinion...
I would get a high flow cat like I did.. save the environment...
Old Sep 8, 2001 | 08:49 PM
KED85's Avatar
800-888-0084
Don's Hot Rod. Get a 2 1/2" in & a 2 1/2" out cc for $60-ish.
Same thing with a fancier box is what ya buy elsewhere.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Sep 8, 2001 | 09:44 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
you should gain a little power by gutting those cats though you may loose a little low end. you would be much better off though by getting a straight pipe instead.
thats the one thing that sux about cats is they create a lot of turbulance and so you lose power across the whole rpm range.
I had three of the bastards on my car and when I took them off and replaced them with a presilencer it made a BIG difference from about 1500-7500 rpms
though granted the difference is in the higher rpms
just go to the muff shop have them make you a bolt on test pipe that is the same size as your cat and then run it. if you dont like it you can always put your cat back on
ICQ 4116192
AIM RXspeed87
Got rotary?
hon-duhs breakfast of champs
gotta love the camaro
PurelyPMD
May 5, 2016 04:57 PM
Stryker412
Sep 20, 2015 06:59 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
89fast5oh
Sep 8, 2015 09:55 AM
