How do I boost the fuel pressure on my 2.8?
Old Sep 10, 2001 | 11:08 PM
Xenodrgn's Avatar
I know you can buy a new Fuel Pressure Regulator... but I've also heard someone say something about using quarters? What? Where is thing, how do I work it, and how do I get more pressure to my failing injectors?! I can feel the car leaning out when I step on it!
1985 Camaro SC - 2.8L, auto.
http://www.xenodrgn.f2s.com/Frontright.jpg
Old Sep 11, 2001 | 01:52 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Running leaner actually gives you more power... it's opposite of what's usually thought (more fuel=more power)- but if you're going too lean, you lose power.
The article on making your own f/p regulator by using some change is in the tech article section of thirdgen.org .
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Sep 11, 2001 | 10:21 AM
KED85's Avatar
Located in the back, in the MIDDLE, under the upper manifold.
BIG circle thing. Schrader valve is VERY close by it!
YOU NEED SPECIAL TORX drivers to remove this thing.
Something in the driving part to push down on a spring release (in the middle) to remove or twist. I know. I found this out. Luckily my buddy had that tool set.
Go get on in the wrecking yard to experiment with. It's on the fuel rail, I believe.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Sep 12, 2001 | 10:21 PM
breathment's Avatar
wut kind of gains would someone expect doing this on a 2.8L?
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
Old Sep 13, 2001 | 11:55 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I believe it depends on other mods... a stock 2.8 might not see any gain. The engine needs to have increased air flow before it can use more fuel... unless, of course, the fuel pump is failing.
I believe the "quarter" method is in the thirdgen.org tech articles. I've seen parts stores sell the "security torx set", which consists of torx sockets that have a hole in the center (to accept the security nub that prevents a normal socket from fitting in). You can grind the nub down. I also hear you can smack the nub with a hammer & punch, but that sounds like too hard of an impact to be good for the injectors.
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
