accel wires
Old Sep 12, 2001 | 09:10 PM
WaynesRS's Avatar
accel wires
I have two boxes of accel 8mm wires .One box I pluged one in the cap and it did not clip on .I took them back to the parts store and told them what happend .They said sorry , we can't take them back b/c you have put one on.Anyway , I have another set that have to be made (you know put the ends on them )I wonder if these are the right wires .Anyone have a number on these accel 8 mm wires ? So i make sure not to get ripped again thanx guys , Wayne
Old Sep 12, 2001 | 10:14 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
I hate those accel wires. I think they are total crap. Ive been looking into the mallory pro wires for the 2.8 with carbon core for 30 bucks from PAW.
1989 Firebird. Modded.
700r4-->t5 w/ram clutch
Cold air, 1.6 rockers, 21lb injectors, 3" y-pipe, random tech cat, 3" ipipe, flowmaster 80 series 3" in 3" out hand made stainless tips, Lakewood LCA's, Msd 6a, Msd coil, Wonder Bar, 180* stat,
Coming Soon: T/a hood, Painted,Spohn Panhard Bar, 4thgen Front Seats, Cam!, Msd 8.5 wires, Posi (ACCEL IS CRAP)
"I'd rather run last in a full out race, than to NOT have run at all"
See my car Here!
In Memory of #3 Dale Earnhardt
Old Sep 13, 2001 | 12:03 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Wayne, did you look inside the boot? Sometimes, inside the boot for the distributor cap end, the wire can twist. The terminal will point sideways a bit, and prevent itself from snapping onto the cap. If the terminal -is- straight (inside the boot), you might try crimping it a bit (through the outside of the boot) with -clean- pliers.
And if that fails, go back to the store, and argue. Try another store (if it was a chain like Pep Boys). See if you can get them to just switch the bad wire for a good wire. And finally, call Accel themselves and complain.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Sep 13, 2001 | 02:08 PM
Brian K's Avatar
Tom is right.... I used to have accel and they worked great. Each year I made new ones and got better each time.. Now I have crane fire wire 8.5MM Wires...
Old Sep 13, 2001 | 02:28 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
I really like my 8mm Accell wires too.
Old Sep 13, 2001 | 05:55 PM
WaynesRS's Avatar
Thanx Guys I'll have to try that with the boots tom . Wayne
Old Sep 13, 2001 | 11:08 PM
KED85's Avatar
Wayne, let's get real. It sounds like you were sold the wrong accel part for your application. How else would you know it wouldn't fit unless you put it on the car?
I have enjoyed accel performance parts since the late 70's. The stuff is great.
I can't say that enough.
I would suggest you go back, find the STORE MANAGER and tell him your story. Still have the receipt?
I have accel parts for all 5 of my rides.
IF they made the parts for my Motorcycle, I'd use it too.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Infested
May 22, 2018 11:56 PM
tazs2000
Jul 15, 2017 08:44 AM
evilstuie
Feb 28, 2016 03:33 PM
355tpipickup
Alternative Port EFI Intakes
Aug 26, 2015 04:08 PM
marcusaw
Aug 10, 2015 08:13 AM
