B&M mega shifter question????
Old Sep 19, 2001 | 11:03 PM
PlayBoy's Avatar
When they discribe this shifter they use the term ratcheting Whadda they mean/???
"Full Ratchet Action!
MegaShifter has that popular 4-speed look with full ratchet action. This shifter is equipped with B&M's precision mechanism that has earned a reputation as the best in the business. Designed so that you can ratchet to all gear positions if desired, or use the trigger activated reverse lock-out to reach the park position. Polished, lighted and complete."
Old Sep 20, 2001 | 03:24 AM
Kevin S's Avatar
What that means is to engage drive,2nd and 1st from OD,you have to pull back release,the shifter for each gear.
Say your in first with the throttle to the floor.You can slap the shifter as hard as you want from 1st to 2nd and it won't go past 2nd.
You can do that all the way to OD.but you can also push it into N from OD with out lifting the lever.
I've had mine for 3 years now.I've not had any problems with the shifter itself.Now the boot is a diff story.
The next time you think your perfect,try walking on water!
[This message has been edited by Kevin S (edited September 20, 2001).]
Old Sep 20, 2001 | 10:52 AM
KED85's Avatar
Think of a ratcheting action of a wrench.
ALSO go to the tranny section. They have SO MANY ANSWERS specifically over there. They definetly know the score!!
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Sep 20, 2001 | 10:56 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Also, you know how your stock shifter changes position, depending on what gear you're in? The B&M Megashifter, when in "ratchet" mode, will point straight up. It's position doesn't change. Like Kevin said, to shift up, you smack the stick forward. When the stick goes forward, it moves to a higher gear, and then it springs backward to the "straight up" position. Same for downshifting... you yank the stick back, and let go; it downshifts, and then springs back to the "upright" position.
The only time the stick changes position is when you go into "reverse" or "park". Like Karl, I installed mine back in '97, and have had no problems... altho I am on my second boot. (Don't armor-all the boot; it'll crack!)
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Sep 25, 2001 | 07:43 PM
PimpRide92's Avatar
I have had mine in for a few months now and I love it. It looks great and is fun to use.
I use Meguyiers Trim detailer on my boot and it wont crack. I use it on all my intieror plastics aswell.
1992 RS 3.1L
Rebuilt Tranny W/
Trans-Go Shift Kit
B&M MegaShifter
B&M Super TransCooler
ES Trans Mount
Dual Snorkel Intake
W/ K&N'S & Custom Ram Air
Flowmaster Exhaust
Accel 300+ Ignition, 8.8mm Wires, Cap/Rotor And Elec. Coil
160* Thermostat
Jet Underdrive Pulley's
1 12" - JL W6 (Loud)
Eclipse 2-Channel Amp
Sony Head Unit
Window Tint 20%
GTS Taillight Blackouts
Red Bowtie Grille
'92 Z28 Wheels W/245-50-16's
Check It Out In The Readers Rides Section Under: PimpRide92
Best Track Time:
1/4 - 17.19 1/8 - 10.88
Spd 1/4 77.19 60' - 2.31
330' - 6.94
Kill's:
80's Stang 4-Cyl, A few Ricers, Ford Tempo(Weak)
'91 OR '92 Z28(Dont Ask Me How) All On A Mesh Up Tranny! 4th Gen 3.4, Cutlas Ciera 3.8,80's V6 Thunderbird,'95 Honda Prelude(2 Fat Guys In It)
'86 IROC-Z 305TPI(My friend said he only had it at 3/4 throttle but he had it pinned and i started pulling in 2nd gear)
colton_carlson
Mar 8, 2019 12:21 PM
camaro11j
Sep 19, 2018 08:49 AM
neekolzun
Aug 24, 2015 04:59 PM
Dialed_In
Aug 20, 2015 01:45 PM
redmaroz
Aug 16, 2015 11:40 PM
