Noisy head
Noisy head
I have a click sound coming from my #5 cylinder. It sounds like a loose rocker arm bolt, or maybe a bent pushrod, or a collapsed lifter or something. Is there anyway that I can better diagnose this problem without guessing and checking. Or is there an oil additive that could make a noisy lifter a little quieter. Thanks for any help.
Might be a valve tap of a loose spark plug wire causing a spark. My friend had a valve tap on his honda. He put it on his engine cleaner machine thingie at work and now you dont hear it anymore.
Hey, thanks for the tip about a short in a spark plug wire. I'm gonnna check into that, before I tear my top end apart. Any other tips would be appreciated.....Thanks
Bad A$$ Boys Drive Bad A$$ Toys
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
