Weight Factor
Old Sep 25, 2001 | 11:19 PM
OneTireFire's Avatar
Weight Factor
Just curious if anyone has ever stripped the inside of there 3rd gen, all excpet the drivers seat, just 2 see the difference it would make on the track. I wonder what kind of difference removing that weight would make?
Thanxs,
Old Sep 26, 2001 | 11:29 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
removing weight is always an easy way to achieve maximum vehicle performance, not when f*rd made the cobra R they removed any and everything that they thought wasn't essential to vehicle performance, not to shabby, unforutnatly the car only performed as well as a Z06 vette, which i would have expected much more. But yeah, say you strip the carpet, rear seats, headliner, dash, center console, front seats, and replace the drivers seat with a lighweight seat, then of course remove everything from the trunk, including the spare tire, you should easily have removed 3 or 4 hundred pounds from the car. That would give you a vehicle that weighs in at say 2700lbs, not to shabby for a 135hp, you could probaly expect times around low low 16's maybe 15's not sure. It'd probaly be comprible to a fiero GT. lol
Old Sep 29, 2001 | 06:41 PM
Red91Bird's Avatar
I rule to go by is for every 200 to 300lbs its like making a extra 30 to 50hp.... good for 1/4 to 1/2 in the quarter mile
David
1974 Ford Maverick Grabber 302 - 1989 roller block, 1995 ported, polished and matched heads, weiand manifold, holly 600cfm carb, headers, 2.25" exhaust. Former owner of a 1991 3.1L Firebird - long live the firebird.
Old Sep 29, 2001 | 11:25 PM
c-5invalid's Avatar
dont forget to remove the shifter ****...
Old Sep 29, 2001 | 11:26 PM
c-5invalid's Avatar
double post...
[This message has been edited by c-5invalid (edited September 29, 2001).]
Old Sep 30, 2001 | 01:19 PM
87 Firebird's Avatar
Floor mats
Sound System (ugh)
The "Firebird" center wheel caps if applicable
Empty washer fluid reservoir
Sail panel covers
I've got a site that says what each thing is worth in weight, also:
damn, can't find it. It's fairly easy to search for, though, IIRC.
Kevin Harlow
87 Firebird - LB8 A4
!Cat, !EGR, !MAF (sometimes), !TB Coolant, Cutout, K&N, Tru-Cool Tranny Cooler, Air Assist Springs, Ported intake, Ported + Polished TB Blade, HPH Level 2 C.A.I. Kit,
Corvette Servo coming soon...
DIY White Face Gauges - www3.mb.sympatico.ca/~bharlow/
Old Sep 30, 2001 | 05:04 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Other things you can do:
Smaller aluminum wheels (13-14 inch)
Skinny front wheels and tires
Remove spoiler (less drag, less weight)
Switch to aluminum flywheel, aluminum driveshaft and disc breaks
Fiberglass: hood, front fascia, rear hatch and doors
Remove GFX
You could also eliminate food from your diet LOL
[This message has been edited by ChillPhatCat (edited September 30, 2001).]
Old Oct 1, 2001 | 09:16 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Hell yeah "smaller tires"... you guys wouldn't believe how friggin' heavy my rear tires are- P275/60r15's on a 15x8 chrome steel rim! I must say I'm thinking of losing the "big tire in back" look for next summer; it's gotta be killing my quarter time. If nothing else, it's just a pain to fit the thing in the backseat when it gets flat!
-Tom P (Hot rodded 1986 Firebird 2.8l)
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
HP52TA
Feb 3, 2018 10:51 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
fbodyfreakls1
Oct 6, 2015 06:34 PM
Damon
Sep 26, 2015 04:29 PM
