Roller Rockers
Old Oct 5, 2001 | 10:27 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Roller Rockers
anyone here ever put in full roller rockers
in their car?
1.5 or 1.6:
Will they even clear the valve covers?
I remenber reading about this before, but cannot find it in the search.
Just asking, new springs mandatory, along witha winning lottery ticket to pay for said full rockers.
$150.00 2.8 Auto.
Blown Head Gasket.
turbo has arrived,
this close / \ to getting parts to fix it.
Old Oct 5, 2001 | 10:42 AM
Monkie's Avatar
We are talking about the Magnum Roller Rockers right?
Old Oct 5, 2001 | 10:43 AM
87 Firebird's Avatar
On the 2.8 and 3.1 blocks, it's not possible without additional machine work. Don't know what exactly, but something about the cam...??
Old Oct 5, 2001 | 11:48 AM
Engine: 5.7 / 7.4
I'm not talking about magnum tips, but full needle bearing "add 20 hp" rollers. I've seen themin PAW for like $365 or so.
Old Oct 5, 2001 | 05:05 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
<font face="Verdana, Arial" size="2">Originally posted by Project: 85 2.8 bird:
Just asking, new springs mandatory, along witha winning lottery ticket to pay for said full rockers.</font>
Sht, the most I ever won on a ticket (scratch-off) was $6.
E-mail the company that makes the rockers... maybe they can help. By the way, a SB chevy uses the same 1.5 rockers we do- the difference is in the rocker arm nut. We use a 10mm metric nut, they use a 3/8 SAE nut. And as ya know, those two are virtually identical thru a socket set; the difference would be in the threads. So if you can't find 'em listed for a 2.8, but can find 'em for a 305, tell the company this info, and ask if there'd be a problem.
Also, see if they make 'em for a f-body 305 with a hydraulic cam. If so, it seems they'd work...
(This is all just guessing, by the way; ask the companies!)
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Oct 5, 2001 | 11:09 PM
Camaro_hunter_d's Avatar
1.5,1.52 will fit. 1.6 you have to "make room with a hammer". Greame knows this one I believe.
Old Oct 5, 2001 | 11:10 PM
Engine: 5.7 / 7.4
the ones i'm looking at are the crane cams gold race $319.95. as for the separate special studs, maybe order those separtely & the rockers for the 8 cyl. himmmmm, could work.
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
