90 Camaro 3.1/Auto - Lacks Power
Old Sep 13, 2011 | 08:38 PM
BushyTea's Avatar
Car: 1990 Camaro
Engine: 3.1 V6
I have a 1990 3.1 camaro that has a ton of new parts on it. New dist, cap, wires, plugs, tps, egr valve, iac, cts, battery, cleaned/flowtested injectors, fuel pressure regulator, rebuilt heads, motors, trans, replaced vacuum lines, cleaned throttle body and set timing to 10* BTDC. I have also completed the idle relearn process. The fuel pressure at idle was at 43 psi.
The problem is the car always starts no problem and very quickly. It idles just fine through the warm up process. Once it is warm the cars idle never fully sets at minimum idle. It tries, then drops a bit then bounces back up but never tries to die. I thought it might need to be driven so I took it out but it lacks power. It just feels like once I take off the car just falls on its face.
At this point I am at a loss and not really sure where to begin next. There are no codes either.
Any idea would be greatly appreciated.
Thanks!
Old Sep 14, 2011 | 01:01 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: 90 Camaro 3.1/Auto - Lacks Power
What about the O2 sensor?
Old Sep 14, 2011 | 08:46 AM
BushyTea's Avatar
Car: 1990 Camaro
Engine: 3.1 V6
I forgot to add that to my original post but the O2 sensor is new as well.
Old Sep 14, 2011 | 09:48 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Were the valves adjusted correctly? IIRC, it is 1-turn past 0-lash.
Many aftermarket shop manuals state a torque setting for the rocker arm nuts, which is incorrect.
RBob.
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
InfinityShade
Aug 22, 2015 08:00 PM
