eratic idle
Old Oct 20, 2001 | 11:34 PM
OneTireFire's Avatar
eratic idle
Hey guyz!!!
Just curious if anybody else has this problem and if anybody knows how 2 correct it? I know that there could be lots of reasons....but any advice would be areciated. When I first start my car in the morning my rpm's jump up, and then they go way down, and then jump back up.....etc. But when my car gets warmed up, this problem is no longer noticable. Thanks in advance for any help.......Jeff
Bad A$$ Boys Drive Bad A$$ Toys
Old Oct 21, 2001 | 03:07 AM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
I think that's normal. My car does it and I think it only does it to warm the car up a little quicker. Correct me if I'm wrong anyone.
1992 Polo Green RS 3.1L K&N conical and working on the ram air....
"Yeah, it's a V6 SO WHAT!?"
Old Oct 21, 2001 | 12:26 PM
87_Camaro's Avatar
I dont have my tached hooked up just yet but as soon as I hook it up i can give you guys an answer.
to me i htink it would be normal, i mean every cra int he morning will run a little ruff until it warms up
Old Oct 21, 2001 | 06:24 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
I beleive that would be fast idle. On cold mornings it will rev up a little higher to get warmed up.
Just to make sure, when it is reving high, give it a good shot of gas, and if it Idles way down after that, its just a Fast idle for the cold...
Old Oct 22, 2001 | 01:22 PM
CD MaroMan 91's Avatar
Mine does that too when I crank it up in the mornings for school. After I go down the street to pick up my friend and leave my neighborhood it stops. It also stops if I just press the gas a few times when in Park. I thought something was wrong with my car lol.
'91 Camaro RS 3.1L V6
4th Gen Seats, Sony Xplod CD Player, DJ Sexay's Kicks Panels on the way, Polk Audio 6½" Comp Set, 2 RF Punch 12's, RF Punch Amp 100.2, Coustic 360W Amp, Kelly Charger Front Tires. Soon to come, New Rims, New Rear Tires, Carpet, Floor Mats, Paint Job, Interior Color Change.
http://www.geocities.com/adidaspredator21/index.html
Old Oct 22, 2001 | 01:36 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
Do the basics, check your (IAC) Idle air control and do a tune up (can't hurt) like check your timing.
Old Oct 22, 2001 | 01:56 PM
BitchinRS's Avatar
It could just be the evap can purging. You might want to check the purge valve. One thing a lot of pepole forget is the filter on the bottom of the evap. can. Check it, if it's dirty replace. It wont hurt and will just ensure tha it is working fine.
Old Oct 22, 2001 | 02:20 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Heh, my car did the same thing this morning. It started normally, then the RPM's dropped, it almost stalled, then it rev'd back up again... did it 3 times, then stabled out. If it does it again, I'll have to check things out this weekend...
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Oct 22, 2001 | 02:46 PM
Alright guyz, thanks for the help!!!
I'm getting a new cap, rotor, plugs, plug wires, evap. can filter, fuel filter, adjusting tps and iac, new o2 sensor, and baro sensor. I figure that i haven't changed these for a while, so i'm probably due anyways. Plus I need 2 get my car smogged real soon, so I may as well get it ready for that. I'm gonna change each of these components one at a time, and start my car inbetween. I'll let ya know what the problems was (if I fix it).
lata
Old Oct 22, 2001 | 02:58 PM
87_Camaro's Avatar
<font face="Verdana, Arial" size="2">Originally posted by TomP:
</font>
wellt hats exactly what my car does in the cold mornings, i turn it on and it goes without a hitch but when the rpm's go down it starts sputtering, till i give it some gas then it perfectly fine.
Old Oct 22, 2001 | 06:22 PM
BitchinRS's Avatar
Have you check your EGR valve? If you have the 2.8L your in luck and you can accualy test it. The 3.1L use a digital EGR valve and none of the repair manuals tell you how to check them.
All though if it is trying to die before it is warmed up you might want to check the IAC,fuel filter, air filter. I have accualy had a dirty air filter keep the car from idling. The car was fight so much to get air it could barly run. If all the usale suppects check out ok try droping some fuel injector cleaner in the tank.
Old Oct 22, 2001 | 06:36 PM
87_Camaro's Avatar
<font face="Verdana, Arial" size="2">Originally posted by BitchinRS:
</font>
i have a brand new fuel filter, have a brand new fuel pump, i have a gutted dual snorkle intkae "bottoms cut out", i have K&N's, and I just poured in some super concentrated fuel injector cleaner to a full tank of 92 octane gas last week since i changed my motor oil a couple of weeks ago and oil pan , in other words im in tip top shape, i will check the EGR valve and i need spark plugs soon, ac delco rapid fires should do the job just fine.
87 V6 2.8 MPFI Camaro SC
Modded dual snorkle intake "bottoms hacked off", K&N air filters, Crane Cams 8.5mm fire wire, Accel Cap and Rotor, MSDcoil. upcoming mods:
Dynomax CatBack exaust system = VERY SOON
crane cams camp shaft, CC roller rockers, double timing chain
Old Oct 23, 2001 | 10:50 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
My EGR's blocked off right now; the thing must be rusty inside- it would engage, and then it wouldn't disengage. (Then the car would stall, wouldn't start, etc...) So I blocked off the vacuum line with an old golf tee; I really gotta replace that valve soon (before January inspection!)
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
