Mild weekend work...
Old Oct 29, 2001 | 10:26 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Did a lube job (last time was July, whoops), and wound up with a creak in my suspension that mysteriously disappeared. https://www.thirdgen.org/messgboard/...ML/003125.html
"Finished" a paint-patch job I did on my driver's side door by sanding the new paint and the old with 1500 grit paper. I had painted the spot but never took down the ridge. I then used that Meguiar's "Swirl remover 2.0" over the spot- wow, what a shine! That made me polish the whole door (minus the 1500 grit sanding though)- wow! https://www.thirdgen.org/messgboard/...ML/003950.html
And finally, I found 3 loose spark plugs. (!) That solved the rattling noise I'd hear while idling! I originally went after the plugs to check the gap; all the gaps are fine. In fact, the #1 cylinder's plug wasn't caked with oily deposits like it usually is! I guess that MSD 6AL box is helping that cylinder out.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Fanatic1074
Oct 3, 2022 05:57 AM
RS Reaper
Oct 17, 2018 07:52 PM
no green
Jan 9, 2016 09:22 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
FueledSoul
Sep 30, 2015 09:18 PM
