Vacuum Leak
Old Oct 1, 2011 | 10:38 AM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
Vacuum Leak
AT first we thought the leak was coming from the manifold itself, which it still may be, but there is a piece of the PCV valve thats broken, and Im pretty sure thats whats causing the stalling, but I have no ideas what the piece is called so I can replace it, it kinda looks like a + but its offset. it connects to the valve cover, something on the back of the motor, and the throttle body itself. I need help identifying it!
Old Oct 1, 2011 | 10:45 AM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
Re: Vacuum Leak
pics are helpful
Old Oct 1, 2011 | 11:00 AM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
Re: Vacuum Leak
I dont know if this helps but its the piece that connects the PCV valve to the intake, to the throttle body.
Attached Thumbnails Vacuum Leak-1985-2.8l-mpi-vacuum
Old Oct 1, 2011 | 11:06 AM
Pillsbry10's Avatar
Re: Vacuum Leak
talking about this?
Old Oct 1, 2011 | 11:14 AM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
Re: Vacuum Leak
Sort of, not exactly
Old Oct 1, 2011 | 11:16 AM
Pillsbry10's Avatar
Re: Vacuum Leak
thats the only thing i could think off hand without a pic
Old Oct 1, 2011 | 11:20 AM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
Re: Vacuum Leak
do you have a V6 or know anyone with one? its literally right beside the distributor and PCV valve, just out of view unless you look at the back of the engine from the strut tower
Old Oct 1, 2011 | 08:47 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Vacuum Leak
You're NEVER going to find an exact replacement. I went to the dealer for one when mine broke off (the big pipe) at the cross. It's called the idle air inlet pipe, and there is NO PART NUMBER for it (listed as NPN in the parts catalogs). A junkyard probably won't help unless you can find an untouched 2.8 older than 88. If you , I've indicated to a couple people how to make one out of heater hose and PVC pipe fittings. However, this requires moving the evap canister vacuum hose to the T on the back of the upper intake, with another T.
Old Oct 2, 2011 | 11:36 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
Re: Vacuum Leak
this is what I was talking about. all three connections were rotted out.
Old Oct 3, 2011 | 09:20 AM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: Vacuum Leak
And, again, that's what I was talking about. There is no replacement. The long black pipe runs to the throttle body and is the idle bypass air intake for the engine through the air inlet on the back of the intake manifold next to the dizzy.
Old Dec 11, 2022 | 08:18 PM
90_camaropnw's Avatar
Re: Vacuum Leak
Originally Posted by Pillsbry10
talking about this?
Hey! When I got my car back from the shop this wasn’t plugged in and that’s when the vacuum leak symptoms started, can someone tell me where this is supposed to plug in at?
Old Oct 2, 2023 | 04:08 PM
Cesarduque44's Avatar
Re: Vacuum Leak
hi did you ever find out how to replace that?
FormulasOnly
Jul 23, 2018 08:47 AM
bbsr72
Apr 2, 2016 09:12 AM
jrdturbo
Mar 31, 2016 02:58 PM
86maro_252
Oct 10, 2015 06:52 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
