stock intake's
Old Oct 2, 2011 | 06:09 PM
92camarorv6's Avatar
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
stock intake's
so what is the bast intake the 3.1 or 3.4 and can you make the 92 camaro a sfi car for batter in town mpg ? and here we go i gave up on the intake setup eith the roost blower i have it made up but i cant figer out the fuel rails so how mush is a set of turbo haeder's
Old Oct 2, 2011 | 08:17 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: stock intake's
You could get a fiero DTB or truleo if you want, though for the money I would just go hybrid personally.
As for SFI, easiest way would be the harness and ECU from a 93 f-bod with a 3.4l. And just do a full engine swap, any other way wouldn't be worth the trouble, not unless the 3.1s have reluctors on the crank, and a drilled boss for the 7x CPS.
Old Oct 3, 2011 | 10:27 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: stock intake's
Going to add some things to the above...
You'll be lucky to find the Truleo intake, and if you do, it's going to be BIG $$$... I'd get the Fiero intake (if it will work, not 100% on that, may need to be made shorter).
He already has a 3.4... All he needs to do is get the hookups (wiring) and the ECM.
There is NO advantage between SFI and MFI in terms of gas mileage... same fuel gets used either way (SFI has bigger injectors for a reason, same injectors on the 3.4 are used on the 3100 SFI). And the SFI reverts to MFI at higher engine speeds anyways to keep the required amount of fuel going into the engine. Pretty much the only advantage the SFI cars have is the ability to monitor 2 O2 sensors to keep the separate banks of cylinders fed with the required fuel and mostly balanced.
Old Oct 3, 2011 | 09:03 PM
Car: 92 camaro rs
Engine: 3.4v6 sc
Re: stock intake's
i was just goting to use the 3.4 top part of the intake i have the older 3.1 it now
Old Oct 3, 2011 | 09:55 PM
Engine: 3.8, 3.4
Re: stock intake's
the 3.4 rwd intake is definitely a better design, they fall on their face kind of low RPMs though, but I am relatively certain its because of the TB opening, its not even as large as the throttle bore on the TB, I hogged mine out to 56, now if I could just figure out how in the hell to run a FWD TB on it.
Old Oct 5, 2011 | 08:03 PM
Car: 92 camaro rs
Engine: 3.4v6 sc
Re: stock intake's
3.4 camaro man thanks for your help i look at the shurter run of the intake and was thinking it would help me out on top end some.and i could play with my fuel ragelar some more
sweet_87_iroc
Sep 25, 2015 10:01 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
PestilenceIV
Aug 20, 2015 02:33 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
