smog pump, do you even need it???
Old Nov 8, 2001 | 04:34 PM
86bird_28v6_5spd_ramair
Guest
Posts: n/a
does it do anything worth while, i just happen to notice it today.
http://PCperformance-usa.com/86bird/86bird.html
Old Nov 8, 2001 | 05:11 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
You do if you want to pass emissions.
1972 Chevy Chevelle "Malibu"
Hooker Headers, Flowmaster 40 series mufflers, accel 8.8 wires,Edelbrock performer intake Edelbrock Carb, Msd Blaster 2 Coil, Torque Thrust "D" wheels
Click here for my Malibu information
In Memory of #3 Dale Earnhardt
Old Nov 8, 2001 | 07:16 PM
JoshDT91's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 2.8L V6
I thought the SMOG pump was a California emmissions thing. If you don't live there I would take it off. Heck if you fail emissions it's not so hard to put it back on.
2.8L V6 173ci
K&N Air Filters
JET Underdrive Pulleys
Old Nov 8, 2001 | 07:19 PM
87chicken's Avatar
mine seized i passed emisions, just before u get in there, rev the **** out of the motor, get the cat really hot and it'll do it's thing, and you'll pass and my injectors are crappy to! heheheh...
Old Nov 9, 2001 | 08:45 AM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
I would leave it on...the HP loss from a smog pump or leaving a cat intact vs gutting it is so minimal, it isn't worth the effort. I always think its funny when someone guts a cat...it's been shown to add 1-2 HP on a 350, so I can't imagine a V6 will see any benefit. As for the smog pump, if it works fine I would leave it be.
Just my .02
Jason E
'89 Camaro RS
-Medium Grey Metallic
-2.8, A4, T-tops, 95k miles
-Hypertech chip, Accel 8.8MM wires and coil
-K&Ns with gutted airbox
-Alpine 60x4 with Boston 746s and RX97s
'97 Z28
-30th Anniversary package (white with orange stripes)
-LT1, M6, t-tops, 46k miles
-Xtant 403a 50x4 + 300x1 powering a 10" Eclipse Aluminum in a JL Stealth box, Boston RM6 fronts, Monsoon rears (temporary!!), Eclipse 5341R CD, All Monster's goodies...
Speed Kills...Wanna live forever? Drive a Ford.
Long Live #3...
Old Nov 9, 2001 | 09:24 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
My '86 2.8 with automatic didn't get a smog pump, so why should an '86 2.8 with a manual trans? It makes no sense to me. If you've got no visual inspection, the 2.8 should be able to pass the sniffer (at idle) with the pump gone.
I don't understand AIR pumps in general, either. Okay, so you've got these emissions in the tailpipe, say. Say, out of 100% exhaust gases, you've got, 10% CO, 10% HC, 10% NOx. Now, lets shove fresh air into the exhaust (with an AIR pump)! That turns the gas amount in your tailpipe into 110% (100% original gas, 10% oxygen). That new "110%" becomes 100% for the smog readings, which turns all those 10%'s (of CO/HC/NOx) into 9.09% of CO, 9.09% of HC, 9.09% of NOx. The fresh air dilutes the exhaust. They might as well hold the exhaust probe "near" the exit of the tailpipe.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Nov 9, 2001 | 12:49 PM
Guest
Posts: n/a
first i could give a **** about emissions, hehehhe, here in ohio we can do what ever we want.
i have already removed the cat. last year and it did help, also gave it some more sound, i just cut it out and put a piece of pipe in its place.
but it would make sence to remove that darn thing, it dont do nothing very important, and i think when its cold out it sticks at startup, cause i allways thought i was my alt. belt never getting tight enough, but then i noticed the smog pump, and i know it could be doing that.
and it is the perferct spot to hook up a second alt.
i do feel sorry for those that must apply to emissions crap, but just a tip for you, i know there is a bottle of stuff you can run in your gas, that will make any car pass the test,seen it on tv.
Old Nov 9, 2001 | 12:56 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
<font face="Verdana, Arial" size="2">Originally posted by 86bird_28v6_5spd_ramair:
</font>
and if we made an elephant disappear on TV you would believe that too, right?
Old Nov 9, 2001 | 03:37 PM
AlexJH's Avatar
Engine: 5.7L V8
Tom, I believe the purpose of the AIR pump is to introduce fresh air that provides additional oxygen to aid the reaction that happends in the catalytic convertor. There is a dilution effect, but I think it goes further than that.
It's been a while since first year chemistry though, I might be wrong
Old Nov 10, 2001 | 09:40 AM
Guest
Posts: n/a
now it was not a tv commercial show selling that stuff, it was a real car show, might
of been crank n chrome before they changed names, but they did there own test and
it worked, not an infomercial.
think the people that make 104+ octane boost made it.
the only problem with public forums, is all the people quick to disagree and have
nothing to do but assume everyone is wrong and enlighten us with their witty opinion.
Old Nov 10, 2001 | 04:31 PM
BitchinRS's Avatar
AlexJH is right the AIR pump only pumps air into the cat or exhuast apsage when it needs it in oder to help the cat function propley befoire it reaches operating temp and other conditions. When it's not needed it will divert the air either into the intake or on some cars into a silencer.
With a computer controlled car you want to leave the EGR and other smog stuff on. If it is not there the computer will still compensate as if it were there and would accualy lower your HP out put. Pepole used to say that removing it help HP becuase they had none computer controlled and did help, but not the computer controlled stuf.
Old Nov 11, 2001 | 05:30 PM
Guest
Posts: n/a
well the removal went great, but all i did was tak off the pully, and got a smaller belt.
wow, i got lots more juice, with lights and everything on, my amp does not dim the lights anymore.
-- the only problem with public forums, is all the people quick to disagree and have
italiano67
Dec 11, 2016 09:21 AM
J.C. Denton
Aug 31, 2015 03:11 AM
Victor6
Aug 30, 2015 02:09 AM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
mustangman65_79
Aug 7, 2015 09:55 PM
