roller rockers
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
roller rockers
which are best to use??? 1.52 or 1.6???
i heard the 1.6 may hit the valve covers, but i am thinking if i put 2 gaskets on instead of one i would some extra clearance............what are the part numbers for these and where can i find them??
if i wanted to install these, i would need to take off the intake manifold
so where would i find new gaskets???
also, how do i put them on???
i have a fairly good idea of how it is done, but i am not completey sure
how do i set the valve lash on them???
i think you swap them like this:
unbolt the old ones (one at a time)
remove it
put the new one on
then set the valve lash
any help would be appreciated
Slayer of the following:
1996 Riced-out Honda Civic (all show and no go!!!!!!)
2000 saturn
198? Ford Crown Vic, (no i don't know why he bothered)
1990 Buick LeSabre 3.8
1986 Camaro 2.8
Newer Ford Explorer
Food that makes me sick: RICE
1991 Camaro RS 3.1 V6 5-speed
1991 Z28 Rims with Firestone Firehawks
dual snorkel intake w/ slashed boxes, 2 K&N's, 180* t-stat, 80 series Flowmaster (sounds AWESOME)
my motto: I CAN'T DRIVE 55
remove it
put the new one on
2000 saturn
1986 Camaro 2.8
Newer Ford Explorer
Car: 1986 Firebird
Engine: 2.8 V6
You can also "jiggle" the pushrod up and down; when you can't wiggle the pushrod up and down anymore, you're at zero lash. My idea of a pushrod being "harder to turn" might be different than yours. When you give the rocker nut the extra 90 degree turn, that sets the preload, from zero lash. What that means is the extra 90 degree turn puts the plungers in the lifters at a "mid" point. That plunger is what makes hydraulic lifters self-adjusting, so by putting the plunger in the middle, you get a good "range" of adjustability.
Oh, the procedure for valve lash is in the Haynes book. You need to spin the crank a few times to get certain valves closed; then you adjust their lash (0 lash w/preload), then you rotate the crank 180 degrees and set the other valves.
-Tom P (Hot rodded 1986 Firebird 2.8l)
[This message has been edited by TomP (edited November 12, 2001).]
KO1
16
Oct 15, 2015 05:00 PM
