Any major difference between Buick 3.8 and Chevy 2.8 ?
I was thinking about the superchargers...
http://cgi.ebay.com/ebaymotors/aw-cg...item=597788860
You can buy these for Buick 3.8 relatively cheap, but can you mount it on the Chevy engine? Are there any troubles with doing that?
It will not WORK... The 3.8 is 90 degrees of fun well teh 2.8 is only 60 degreees of fun.... You can get a procharger for the 350 and modify the connection to the TB if you really want a super, but I highly recomend the bottle for the cost and efficency. You will get great mileage and less wear since you will use it so less often..
<font face="Verdana, Arial" size="2">Originally posted by Brian K:
It will not WORK... The 3.8 is 90 degrees of fun well teh 2.8 is only 60 degreees of fun.... You can get a procharger for the 350 and modify the connection to the TB if you really want a super, but I highly recomend the bottle for the cost and efficency. You will get great mileage and less wear since you will use it so less often..</font>
<font face="Verdana, Arial" size="2">Originally posted by Camaro_hunter_d:
or you could always scratch build a Turbo kit for it.</font>
Could you recommend some? What types exactly? Where to look for in the Net?
