Attn: TomP
Attn: TomP
Can you tell me about your Energy Suspension End Link Kit? What I am wondering is how hard it is to put these in? And I have been wondering I plan on getting a Addco Rear Sway bar but I am wondering how easy this is to install. I don't know too much about suspension. So could ya help me out? Thanks alot man!
Car: 1986 Firebird
Engine: 2.8 V6
Do a search for these items on the Suspension/Chassis board, you'll find my old messages. And as for difficulty, if you can really take an engine apart and put it back together in a day, neither of these should be worrying you.
[This message has been edited by TomP (edited November 15, 2001).]
Car: 1986 Firebird
Engine: 2.8 V6
Wow, weird.. it all just bolts on, and unbolts... sometimes the end links rust together; they have a metal sleeve with a thru-bolt, and the bolt rusts to the sleeve. You can undo the nut, and remove the end link from the anti-sway-bar, but the rusted sleeve will "hold" the end link to the front control arm (or rear body bracket).
I used a cutting tip on a soldering iron to slice the bushings out of there, then I used a pair of bolt cutters to snip off the thru-bolt's head.
-Tom P (Hot rodded 1986 Firebird 2.8l)
87_Camaro
Aug 29, 2001 04:41 PM
