!!!!! its not my tranny mount!!!!!
Old Nov 16, 2001 | 09:06 PM
mybeamoflight's Avatar
recently I post a topic in which I state that my rear end was knocking. I gain a lot of advice. anyway today I lifted my 92 rs up and took a look. my tranny mount is in perfect shape. so its not the tranny mount. my bushings are a little cracked could that be it? or maybe I could have broken a gear in my axle?? please help!
Old Nov 16, 2001 | 09:20 PM
camaro6spd's Avatar
yo...my IROC had the same problem....the torque arm was loose and would let the rear rotate untill it hit something and you would get the knock. Check it out....the two big bolts and then they ones buy the tranny.
1987 Black 305 TPI 5spd IROC, G92, 9-bolt 3.45, Lowered, Cat-back, Air Foil, Sub Frames, Huge sways........Wrecked by a deer.
Looking for a 1995 Honda CR125R in NJ or PA. I have one for sale...RRP Sleeve Job, Vertex Piston, New Sprokets and a x-ring chain, new botom end with crank...etc etc
look here
http://www.classifieds2000.com/cgi-cls/ad.exe?P1+C18+R100004616
AIM: IROC 5spd
http://www.geocities.com/chevy5spdiroc/87Roc.htm
Old Nov 17, 2001 | 12:21 AM
Camaro_hunter_d's Avatar
<font face="Verdana, Arial" size="2">Originally posted by camaro6spd:
</font>
also check the torque arm bushing, they rot out easily and cause the same thing. Every time you do a hard or even semi hard accel Click Click Boom!.
GouldyGTR
Sep 7, 2015 09:05 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
