DOES ANY KNOW WHERE I CAN GET A 2.8L CARB?!!?
Old Nov 19, 2001 | 07:47 PM
1984Firebird502's Avatar
I currently have an S10 noncomputer controlled carb on my car and it's running really bad, very choppy. At autozone they are $400. What the heck?!? And please don't tell me junk yard. Also, don't tell me to get the Edelbrock intake and small 4 barrel (although if any of you is selling that tell me ) Or, does anyone have one I can buy off them? Thanks.
1984 Firebird SE
1985 Camaro z28 305 engine T-5 Five Speed Tranny, 92 Camaro Leather Seats Console, carpet everything. Soon to put in 700R4 and 427CI. (Hopefully.
To view my car go to:
http://geocities.com/jmboriss/bluecar.html
It is for sale, asking $2000.
Old Nov 19, 2001 | 08:04 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Did you check ebay?
I dont know why the Azone one would be so expensive are you sure they quoted your correctly? I'll do some checking and edit this post later.
SSC
EDIT: What a rip off! If I were you I would swap an s10 distrubutor in and eliminate the computer. Does the s10 carb have the Mixture controll plug in on it?
What happend to your old carb?
85 Camaro, 355/400 "drag car" current DD 13.1@ 101mph on its last season run.
Plans: Possibly add N20 for next season.
82 Firbird, rebuilt 355 for it and slaped a 700r4 in. The 700r4 crapped out so back to the tb350
[This message has been edited by SSC (edited November 19, 2001).]
Old Nov 19, 2001 | 08:32 PM
I know right?!!? 400 freakin' dollars! I called them 3 times in 2 days with 3 different people answering to make sure. It is! I'll check ebay. I bought the car for $600 and he told me the check engine light was on because it's a s10 carb, but it ran fine. Now, I know the problem! It's that dang carb! I'll call the old owner and ask if he still has the carb, I doubt it though. I'll check ebay right now. THanks.
Old Nov 19, 2001 | 09:03 PM
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
Why don't you just rebuild the carb.
Chevy 2.8L 60° V6
Mods:
?K&N Filter Lid
?87 Formula Hood
?Bosch Platinum +4
?Hi-Flo CatCo CAT
?Flowmaster 80 Series Muffler
?83 Trans Am 15x7 Turbo Fin Wheels
?B.F.Goodrich Radial T/A 225/60-15
?Chevy 2.8L Heddman Headers (Going on soon)
Aol instant messenger: FIREAM
<A HREF="http://digilander.iol.it/simpson50/1_multimedia/simpson/gif_animate/06/homer_14.gif
http://www.geocities.com/fiream/RobsCarArtPa.html?994187591828" TARGET=_blank>http://digilander.iol.it/simpson50/1_multimedia/simpson/gif_animate/06/homer_14.gif
http://www.geocities.com/fiream/RobsCarArtPa.html?994187591828</A>
Old Nov 19, 2001 | 09:04 PM
Brian K's Avatar
Summit Racing....
Old Nov 19, 2001 | 10:10 PM
<font face="Verdana, Arial" size="2">Originally posted by fiream:
</font>
Because it's NOT THE RIGHT CARB!! I don't have the right carb. The carb on there right now is from an S10. I need one from an Fbody that is Computer controlled. Thanks.
Old Nov 19, 2001 | 10:28 PM
fiream's Avatar
Engine: 400HP 350
i'm putting a non-ccc carb on my car and it should run fine, and i do have a vacuum advance distributor that I found in a junkyard.
Chevy 2.8L 60° V6
Mods:
?K&N Filter Lid
?87 Formula Hood
?Bosch Platinum +4
?Hi-Flo CatCo CAT
Old Nov 19, 2001 | 10:34 PM
KED85's Avatar
Open up the phone book to start visiting wrecking yards.
Then ya buy it
Then ya rebuild it
Ya probably be close to the $400.
Sad, but, quite possible.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Nov 20, 2001 | 05:48 AM
Why are the 2.8 engines so crappy? I mean, I don't have much options here. I'll try the junk yards and stick with the stock distributor and stock carb. Next 'bird I'm getting is Fuel Injected!!
Old Nov 20, 2001 | 11:02 AM
KED85's Avatar
Here, try this place in downtown LA.
M & M carb
213-748-7261
I've been dealing with them since 1982
They may have a MORE INEXPENSIVE option.
You have a great foundtion to install an easy V-8 swap.
Nothing to deal with but an engine & car.
Find a wreck and do the swap.
Same dollars & effort, better results.
Chat Soon,
KED85
Karl
Old Nov 20, 2001 | 12:02 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
502, your best cheapest way out is to install a vac advance distributor from a S10. Its around $40 used and takes 20 min to install. Once that $40 piece is in place then you can get your carb rebuilt, so your looking around $240 vrs $400. Im not 100% on this but I think some of the old station wagon 4 bangers had a cc carb. I know its the same as the carb for thge 2.8 but it might have different linkage, it's not a problem if you have a standard.
Just a thought.
SSC
Old Nov 20, 2001 | 03:40 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I had a friend with an '83 Camaro; his carb went bad, so I got him a junkyard carb for $35. We swapped it on, and he drove around on it for a bit until he had the cash to get it rebuilt. He found a local carb guy, and it cost him around $50 or $60 to have it rebuilt. The guy was an old pro, though... he had trouble finding someone that wanted to do the job, and he wound up finding the "best".
The E2SE isn't as complicated as the E4ME, in fact, my Haynes 82-92 gives a step-by-step, photo-by-photo rebuild of that 2bbl carb.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Nov 20, 2001 | 03:45 PM
What the heck?!!? THANKS but the problem is not rebuilding the carb!! It's FINDING ONE. I HAVE AN S10 ON THERE NOW!!! I NEED AN FBODY ONE!!!!
Old Nov 20, 2001 | 04:49 PM
KED85's Avatar
Have you phoned M & M carb in LA?
They probably have one & it'll be about $100 already rebuilt.
Don't tell them you have the non computer controlled carb for the "exchange".
Just do a mail order.
Chat Soon,
KED85
Karl
Old Nov 20, 2001 | 08:29 PM
Hey, Thanks a lot. Do you they have a website address? I would rather not call CA, you know how that goes. I will if I have to though.
Old Nov 20, 2001 | 09:46 PM
HAPPYHAPPYHAPPY's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 1984Firebird502:
</font>
sounds like a real piece of work. good luck getting that thing running descent
Old Nov 20, 2001 | 11:28 PM
KED85's Avatar
No. M & M does not have a web site.
I'll call them in the AM & pass along the answer for ya.
Chat Soon,
KED85
Karl
Old Nov 21, 2001 | 09:13 AM
Thanks a lot.
Old Nov 21, 2001 | 11:34 AM
Krush 32's Avatar
I currently have an S10 noncomputer controlled carb on my car and it's running really bad, very choppy. At autozone they are $400. What the heck?!? And please don't tell me junk yard. Also, don't tell me to get the Edelbrock intake and small 4 barrel (although if any of you is selling that tell me ) Or, does anyone have one I can buy off them? Thanks.if u can wait a couple of weeks I might be getting one for free!!!!!!
</font>
Old Nov 21, 2001 | 04:07 PM
Really? Thanks a lot man. That would be awesome. Email me if you can. Thanks.
RedLeader289
May 28, 2019 01:47 PM
efiguy
Sep 27, 2015 01:30 PM
Damon
Sep 26, 2015 04:29 PM
lanceflame44
Sep 25, 2015 12:28 PM
